... I don't define the columns in the code ...
... The columns come from the query results and are set dynamically ...
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"> <!-- Adobe Flex SDK 4.5.1 --> <!-- ArcGIS API for Flex 2.5 --> <!-- http://web.zone.ee/bespiva/queryresults/ --> <s:layout> <s:VerticalLayout gap="10" paddingLeft="10" paddingBottom="10" paddingRight="10" paddingTop="10"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.LayerEvent; import com.esri.ags.layers.FeatureLayer; import com.esri.ags.layers.supportClasses.Field; import com.esri.ags.tasks.supportClasses.Query; import mx.collections.ArrayCollection; import mx.rpc.AsyncResponder; import mx.rpc.Fault; import mx.utils.StringUtil; import spark.components.gridClasses.GridColumn; [Bindable] private var gridSource:ArrayCollection = new ArrayCollection(); [Bindable] private var gridColumns:ArrayCollection = new ArrayCollection(); private var queryLayer:FeatureLayer = null; private function initializeLayer():void { queryLayer = new FeatureLayer(txtServiceUrl.text); queryLayer.mode = FeatureLayer.MODE_ON_DEMAND; queryLayer.outFields = new Array("*"); queryLayer.addEventListener(LayerEvent.LOAD, onLayerLoaded, false, 0, true); dispatchEvent(new LayerEvent(LayerEvent.LOAD, queryLayer)); } protected function onLayerLoaded(event:LayerEvent):void { queryLayer.removeEventListener(LayerEvent.LOAD, onLayerLoaded); txtServiceUrl.editable = false; executeQuery(); } protected function onExecuteButtonClick(event:MouseEvent):void { if (queryLayer != null && queryLayer.loaded) { executeQuery(); } else { initializeLayer(); } } private function executeQuery():void { var query:Query = new Query(); query.where = txtWhere.text; query.returnGeometry = false; var outs:Array = StringUtil.trim(txtOuts.text).split(","); query.outFields = queryLayer.outFields = outs; queryLayer.queryFeatures(query, new AsyncResponder(onQueryResult, onQueryFault)); } protected function onQueryResult(featureSet:FeatureSet, token:Object = null):void { gridSource = new ArrayCollection(); lblResultsCount.text = StringUtil.substitute("Found: {0} features.", featureSet.features.length); for each(var gr:Graphic in featureSet.features) { gridSource.addItem(gr.attributes); } gridSource.refresh(); gridColumns = new ArrayCollection(); for each (var field:Field in featureSet.fields) { var gridColumn:GridColumn = new GridColumn(field.alias); gridColumns.addItem(gridColumn); } gridColumns.refresh(); } protected function onQueryFault(fault:Fault, token:Object = null):void { trace(fault.getStackTrace()); } ]]> </fx:Script> <s:Panel width="100%" title="Query parameters"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%"> <s:HGroup width="100%"> <s:Label text="Url:" width="150" /> <s:TextInput id="txtServiceUrl" width="100%" text="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Where clause:" width="150" /> <s:TextInput id="txtWhere" width="100%" text="1=1" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Out fields (CSV):" width="150" /> <s:TextInput id="txtOuts" width="100%" text="STATE_NAME,STATE_FIPS,SUB_REGION,STATE_ABBR,POP2000,POP2007" /> </s:HGroup> <s:HGroup width="100%"> <s:Button label="Execute" click="onExecuteButtonClick(event)" /> </s:HGroup> </s:VGroup> </s:Panel> <s:Panel title="Results" width="100%" height="100%"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%" height="100%"> <s:Label id="lblResultsCount" /> <s:DataGrid width="100%" height="100%" dataProvider="{gridSource}" columns="{gridColumns}"/> </s:VGroup> </s:Panel> </s:Application>
<s:DataGrid> <s:columns> <s:ArrayList> <!-- Define columns propeties here --> <s:GridColumn dataField="filedName4"/> <s:GridColumn dataField="filedName2"/> <s:GridColumn dataField="filedName1"/> <s:GridColumn dataField="filedName3"/> </s:ArrayList> </s:columns> </s:DataGrid>
[Bindable] private var dataGridAC:ArrayCollection = new ArrayCollection(); private var floatGrid:queryWidgetDG; public function mssqlQuery(sql:String,fid:String):void { var http:HTTPService = new HTTPService; var parm:Object = new Object; parm.fas_sql = sql; parm.fas_db = mssql_db; http.url = mssql_url+"?irand="+Math.random(); http.showBusyCursor = true; http.request = sql; http.addEventListener(ResultEvent.RESULT, mssqlResult); http.addEventListener(FaultEvent.FAULT, mssqlFault); http.method = "POST"; sqlToken = http.send(parm); sqlToken.param = fid; } private function mssqlResult(event:ResultEvent):void{ if (event.result.results){ dataGridAC.removeAll(); dataGridAC = event.result.results.record; getgridData(); }else{ Alert.show("No data found"); } } private function getgridData():void{ PopUpManager.removePopUp(floatGrid); floatGrid.btnString = "StationID"; floatGrid.stringTitle = "Temperature" + " Data at " + wqStreamNameList.selectedItem.StreamName; floatGrid.data = dataGridAC; showGrid(); } //this function will add the grid to the app protected function showGrid():void{ if(!floatGrid){ floatGrid = queryWidgetDG(PopUpManager.createPopUp(map,queryWidgetDG,false)); PopUpManager.centerPopUp(floatGrid); //myChart = queryWidgetChart(PopUpManager.createPopUp(map,queryWidgetChart,false)); }else{ PopUpManager.addPopUp(floatGrid,map,false); PopUpManager.centerPopUp(floatGrid); // PopUpManager.addPopUp(queryWidgetChart,map,false); } }
Farhad, So where is this place you define it? I have not found documentation that confirms this statement. Query result is feature set. Try it, may be it helps you. <?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"> <!-- Adobe Flex SDK 4.5.1 --> <!-- ArcGIS API for Flex 2.5 --> <!-- http://web.zone.ee/bespiva/queryresults/ --> <s:layout> <s:VerticalLayout gap="10" paddingLeft="10" paddingBottom="10" paddingRight="10" paddingTop="10"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.LayerEvent; import com.esri.ags.layers.FeatureLayer; import com.esri.ags.layers.supportClasses.Field; import com.esri.ags.tasks.supportClasses.Query; import mx.collections.ArrayCollection; import mx.rpc.AsyncResponder; import mx.rpc.Fault; import mx.utils.StringUtil; import spark.components.gridClasses.GridColumn; [Bindable] private var gridSource:ArrayCollection = new ArrayCollection(); [Bindable] private var gridColumns:ArrayCollection = new ArrayCollection(); private var queryLayer:FeatureLayer = null; private function initializeLayer():void { queryLayer = new FeatureLayer(txtServiceUrl.text); queryLayer.mode = FeatureLayer.MODE_ON_DEMAND; queryLayer.outFields = new Array("*"); queryLayer.addEventListener(LayerEvent.LOAD, onLayerLoaded, false, 0, true); dispatchEvent(new LayerEvent(LayerEvent.LOAD, queryLayer)); } protected function onLayerLoaded(event:LayerEvent):void { queryLayer.removeEventListener(LayerEvent.LOAD, onLayerLoaded); txtServiceUrl.editable = false; executeQuery(); } protected function onExecuteButtonClick(event:MouseEvent):void { if (queryLayer != null && queryLayer.loaded) { executeQuery(); } else { initializeLayer(); } } private function executeQuery():void { var query:Query = new Query(); query.where = txtWhere.text; query.returnGeometry = false; var outs:Array = StringUtil.trim(txtOuts.text).split(","); query.outFields = queryLayer.outFields = outs; queryLayer.queryFeatures(query, new AsyncResponder(onQueryResult, onQueryFault)); } protected function onQueryResult(featureSet:FeatureSet, token:Object = null):void { gridSource = new ArrayCollection(); lblResultsCount.text = StringUtil.substitute("Found: {0} features.", featureSet.features.length); for each(var gr:Graphic in featureSet.features) { gridSource.addItem(gr.attributes); } gridSource.refresh(); gridColumns = new ArrayCollection(); for each (var field:Field in featureSet.fields) { var gridColumn:GridColumn = new GridColumn(field.alias); gridColumns.addItem(gridColumn); } gridColumns.refresh(); } protected function onQueryFault(fault:Fault, token:Object = null):void { trace(fault.getStackTrace()); } ]]> </fx:Script> <s:Panel width="100%" title="Query parameters"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%"> <s:HGroup width="100%"> <s:Label text="Url:" width="150" /> <s:TextInput id="txtServiceUrl" width="100%" text="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Where clause:" width="150" /> <s:TextInput id="txtWhere" width="100%" text="1=1" /> </s:HGroup> <s:HGroup width="100%"> <s:Label text="Out fields (CSV):" width="150" /> <s:TextInput id="txtOuts" width="100%" text="STATE_NAME,STATE_FIPS,SUB_REGION,STATE_ABBR,POP2000,POP2007" /> </s:HGroup> <s:HGroup width="100%"> <s:Button label="Execute" click="onExecuteButtonClick(event)" /> </s:HGroup> </s:VGroup> </s:Panel> <s:Panel title="Results" width="100%" height="100%"> <s:VGroup gap="5" paddingLeft="5" paddingTop="5" paddingRight="5" paddingBottom="5" width="100%" height="100%"> <s:Label id="lblResultsCount" /> <s:DataGrid width="100%" height="100%" dataProvider="{gridSource}" columns="{gridColumns}"/> </s:VGroup> </s:Panel> </s:Application>
I could use your sample code with a small change. I declared gridColumns as Array instead of ArrayCollection.
columns propertycolumns:IList
1067: Implicit coercion of a value of type Array to an unrelated type mx.collections:IList. ...
