dojo.require("dojo.fx")
I'm not sure of the issue - I'm using the TOC code here http://maps2.eastdevon.gov.uk/mapping/assets/ and it works fine in all browsers now (mine is slightly modified to take visible layers rather than default visibility - I did this before the core code was changed to do this)ACM
I have exactly the same problem: when you run my app in IE9 the fist time it works however after it rerun again TOC it is not displayed any more - same happen with http://gmaps-utility-gis.googlecode.com/svn-history/r354/trunk/agsjs/examples/toc.html. I have tried to destroy dom and widjet itself - but it did not help. Is there any solution for it?
I have noticed that I have to reload my page in order to get the TOC to display. I can see that the agsjs.dijit.TOC is created on the initial load of the page, but the results do not show up in my 'tocDiv'. I have also experienced this behavior on the internet example site http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.02/examples/toc.html on the initial load the TOC does not show, but if I refresh in IE8, it does. Just wondering if there is a work around to address this behavior. Thanks, Mele
HiThis works fine, but of course the TOC code doesn't pick up on the changed visibility and shows all layers unticked (the default state) Any ideas how I should call a refresh or something of the TOC to get the boxes ticked?
_createRootLayerTOC: function () { var b = this.rootLayer; if (!b._tocInfos) { var c = {}; dojo.forEach(b.layerInfos, function (d) { c["" + d.id] = d; console.debug(d) if (contains(defaultlayers,d.name)) { d.visible = true; } else { d.visible = false; } .....
function defaultvis(layer) { visible = []; var items = dojo.map(layer.layerInfos, function (info, index) { if (contains(defaultlayers, info.name)) { visible.push(info.id); console.debug(info.name + "ative") } else { console.debug(info.name) } }); dynamicMapServiceLayer.setVisibleLayers(visible); }
