import pyodbc import json import shutil import collections import time import os os.environ['TDSVER'] = '8.0' connstr = 'DRIVER={SQL Server};SERVER=SERVERNAME;DATABASE=DATABASENAME;' conn = pyodbc.connect(connstr) cursor = conn.cursor() cursor.execute(""" SELECT field1, field2, field3 FROM TABLENAME """) rows = cursor.fetchall() # Convert query to row arrays rowarray_list = [] for row in rows: t = (row.field1, row.field2, row.field3) rowarray_list.append(t) j = json.dumps(rowarray_list) rowarrays_file = 'C:\Production\calculation\marcWells_rowarrays.js' f = open(rowarrays_file,'w') print >> f, j # Convert query to objects of key-value pairs objects_list = [] for row in rows: d = collections.OrderedDict() d['field1'] = row.field1 d['field2'] = row.field2 d['field3'] = row.field3 objects_list.append(d) j = json.dumps(objects_list) objects_file = 'C:\Production\calculation\marcWells_objects.js' f = open(objects_file,'w') print >> f, j date_string = time.strftime("%Y%m%d%H%M%S") shutil.copyfile('C:\Production\input\marcWells_objects.js', r'C:\Production\input\marcWells_objects_' + date_string + '.js') conn.close()
mport shutil shutil.copyfile('C:\Production\calculation\marcWells_objects.js', r'C:\Production\input\marcWells_objects.js') conn.close()
def main(): import socket UDP_IP = '127.0.0.1' UDP_PORT = 5005 sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) sock.bind((UDP_IP,UDP_PORT)) while True: data, addr = sock.recvfrom(1024) # buffer size is 1024 bytes print 'received message:', data if __name__ == '__main__': main()
def main(): import socket UDP_IP = '127.0.0.1' UDP_PORT = 5005 MESSAGE = 'Hi.' print 'UDP target IP:', UDP_IP print 'UDP target port:', UDP_PORT print 'Message:', MESSAGE sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) sock.sendto(MESSAGE, (UDP_IP,UDP_PORT)) if __name__ == '__main__': main()
import socket UDP_IP = 'localhost' UDP_PORT = 5565 MESSAGE = 'Vehicle,124,Truck,25,2012-07-24T08:11:00,"-117.192914,34.056459"' print 'UDP target IP:', UDP_IP print 'UDP target port:', UDP_PORT print 'Message:', MESSAGE sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) sock.sendto(MESSAGE, (UDP_IP,UDP_PORT))
import os, sys import time, argparse import socket def sendData(sock, dataPath, interval): dataFile = None i = 0 try: interval = float(interval / 1000.0) #open simulation data file and send data dataFile = open(dataPath, "r") print "Opened data file: %s" % dataPath for l in dataFile: sock.send(l) time.sleep(interval) dataFile.close() dataFile = None return True except Exception as e: raise Exception("Error sending data: %s" % e) finally: if dataFile: dataFile.close() #make argument parser to handle user command line input parser = argparse.ArgumentParser(description="Start a simulated data feed for a GeoEvent Processor tcp text input") parser.add_argument("-d", "--data", help="path to file containing csv data. Default is ../data/sources/AsdiUal_sub.csv", default="../data/sources/AsdiUal_sub.csv") parser.add_argument("-p", "--port", help="tcp socket port. Default is 5565", type=int, default=5565) parser.add_argument("-n", "--name", help="host name of server to connect to. Default is 'localhost'", default="localhost") parser.add_argument("-i", "--interval", help="interval in milliseconds between messages. Default is 500. Maximum interval is 5 seconds", type=int, default=500) if __name__ == "__main__": args = parser.parse_args() if args.interval > 5000: print "Warning: interval cannot be more than 5 seconds. Setting interval to 5 seconds" args.interval = 5000 if args.interval < 0: print "Warning: Invalid interval value. Setting interval to default value" args.interval = 1000 #begin simulation tcpSocket = None cont = True try: #Check if data file exists if not os.path.exists(args.data): raise Exception("Data file not found: %s." % args.data) #open socket tcpSocket = socket.create_connection((args.name, args.port)) print "Opened tcp socket on %(name)s:%(port)s" % {"name": args.name, "port": args.port} while cont: sendData(tcpSocket, args.data, args.interval) except Exception as e: print "Error: %s" % e finally: if tcpSocket: tcpSocket.close()
