If you want to discuss this further, just post your e-mail. 🙂
import ftplib import os import sys import traceback print "Logging in..." ftp = ftplib.FTP() ftp.connect('ftphostname') print ftp.getwelcome() try: try: ftp.login('username', 'password') ftp.cwd('target directory') # move to the desired upload directory print "Currently in:", ftp.pwd() print "Uploading...", fullname = '../sourcedirectoy/filename' name = os.path.split(fullname)[1] f = open(fullname, "rb") ftp.storbinary('STOR ' + name, f) f.close() print "OK" print "Files:" print ftp.retrlines('LIST') finally: print "Quitting..." ftp.quit() except: traceback.print_exc()
# Written by Jesusa M. Romero on 06/10/10. # Script Description: # 1) Deletes the existing folders AND files on FTP # 2) Lists folders on rcant7 and creates the same list of folders on FTP # 3) Transfers TIF images from rcant7 to the corresponding folders on FTP # 4) Deletes the list of folders on rcant7 # Note: The "notes.txt" file on rcant7 isn't transferred or deleted. # ---------------------------------------------------------------------------# import ftplib, os, shutil, sys startpath = r"\\rcant7\data\MAPPING\GIS\Images" ftp = ftplib.FTP('IP ADDRESS GOES HERE') ftp.login('USERNAME', 'PASSWORD') directory = '/ACR_Images/' ftp.cwd(directory) print "Script: Image transfer from Rcant7 to Survey FTP now executing..." print " " ftpdirset = ftp.nlst(directory) for ftpd in ftpdirset: dirfold = directory + ftpd print "Visiting existing FTP folders/files: " + dirfold try: ftp.delete(dirfold) print "FTP file deleted: " + dirfold print "-" * 70 except: ftpfiles = ftp.nlst(dirfold) for ftpfile in ftpfiles: dirfoldfile = dirfold + "/" + ftpfile print " File in folder deleted: " + dirfoldfile ftp.delete(dirfoldfile) ftp.rmd(dirfold) print "FTP folder deleted: " + dirfold print "-" * 70 print "-" * 70 print "FTP directory " + directory + " has been emptied." print "Images will be transferred." print "-" * 70 print "-" * 70 print " " dirListST = os.listdir(startpath) for folder in dirListST: if os.path.isdir(startpath + "\\"+ folder): print "Creating new " + folder + " folder in FTP " + directory print "Transferring files to FTP now..." ftp.cwd(directory) ftp.mkd(folder) stpathfolder = os.path.join(startpath, folder) dirListST2 = os.listdir(stpathfolder) for specfile in dirListST2: basename, extension = specfile.split(".") pathforspecfile = stpathfolder + "\\" + specfile ftp1 = startpath + "\\"+ folder + "\\" + specfile ftp.cwd(directory + folder + "/") if extension == "tif" or extension == "txt": f = open(ftp1,"rb") a = "STOR " + specfile ftp.storbinary (a, f) print " Transfer completed for " + specfile f.close() else: print " File not transferred: " + specfile print stpathfolder + " has been deleted." shutil.rmtree(stpathfolder) else: print "*** " + folder + " is not a directory. Not transferred from Rcant7." print "-" * 70 print "-" * 70 print "IMAGE TRANSFER HAS BEEN COMPLETED." ftp.quit()
Sounds crazy but you have to trust me here. If you are going to use storbinary, the file cant be opened in binary mode. I know what you are going to say but I just figured this out in the last couple weeks myself and it just doesnt work.fileList=[]for i in os.listdir(dir): if i.split('.')[1] == 'pdf' #if it ends in pdf fileList.append(i) #put it in the listftp = FTP("xyz.xyz.xyz.xyz",username, password) #save a line and just put your U:P here.for i in fileList: file = open(i, "r") #open in normal read mode ftp.cwd("//data2//ftp//pub//download//maps//") ftp.storbinary('STOR %s' % i, os.path.join('V://GIS//Maps//County//11x17shd//',i)) file.close()ftp.quit()
ftp = FTP("xyz.xyz.xyz.xyz",username, password) #save a line and just put your U:P here. for i in fileList: # don't use double //, this will rely on the server to properly handle it (most will) # also don't use a trailing slash since VAX/RSIC will try the folder "maps/" ftp.cwd("/data2/ftp/pub/download/maps") # ftp.storbinary takes a FILE object not a path, python will automatically close the file ftp.storbinary('STOR %s' % i, open(os.path.join('V://GIS//Maps//County//11x17shd//',i), "rb")) ftp.quit()
On Windows, 'b' appended to the mode opens the file in binary mode, so there are also modes like 'rb', 'wb', and 'r+b'. Python on Windows makes a distinction between text and binary files; the end-of-line characters in text files are automatically altered slightly when data is read or written. This behind-the-scenes modification to file data is fine for ASCII text files, but it�??ll corrupt binary data like that in JPEG or EXE files. Be very careful to use binary mode when reading and writing such files. On Unix, it doesn�??t hurt to append a 'b' to the mode, so you can use it platform-independently for all binary files.
ftp = FTP("xyz.xyz.xyz.xyz",username, password) #save a line and just put your U:P here. for i in fileList: ftp.cwd("/data2/ftp/pub/download/maps") # Manually tell the server to change to binary mode: # I indicates Binary, # A indicates text # There are a few other transfer modes however they are not used very often # just print the return message, if its an error ftplib will raise an exception print ftp.sendcmd("TYPE I") # ftp.storbinary takes a FILE object not a path, python will automatically close the file ftp.storbinary('STOR %s' % i, open(os.path.join('V://GIS//Maps//County//11x17shd//',i), "rb")) ftp.quit()
#Import system modules import os, shutil File2Send = "V:\\GIS\\Maps\\County\\11x17shd" #New maps folder FTP_Server = "F:\\ftp_server\\GIS_Maps" #FTP server folder #Get the list of files f = [f for f in os.listdir(File2Send) if os.path.isfile(os.path.join(File2Send, f))] #Loop through the list for i in (f): if os.access(FTP_Server + "\\" + i, os.F_OK): #Check for existing file os.remove(FTP_Server + "\\" + i) #Remove existing file shutil.copy(File2Send + "\\" + i, FTP_Server + "\\" + i) #Copy new file
