I've got one FeatureLayer with a popup in the map. I'm trying to use the SketchViewModel sample for sketching temporary geometries. How can I disable popups while the sketching is active so clicking on a feature in the FeatureLayer doesn't open the popup?
Blake,
OK, it seems that the point draw-complete is fired before the mapView hittest is returned.
Here is the fix:
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"draw-complete"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> myFeatureLayer<SPAN class="punctuation token">.</SPAN>popupEnabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">200</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Yes, for example:
<SPAN class="comment token">// *************************************</SPAN> <SPAN class="comment token">// activate the sketch to create a point</SPAN> <SPAN class="comment token">// *************************************</SPAN> <SPAN class="keyword token">var</SPAN> drawPointButton <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"pointButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> drawPointButton<SPAN class="punctuation token">.</SPAN>onclick <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> myFeatureLayer<SPAN class="punctuation token">.</SPAN>popupEnabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// set the sketch to create a point geometry</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">create</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"point"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setActiveButton</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Then I set it back to true in the on draw-complete function:
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"draw-complete"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> myFeatureLayer<SPAN class="punctuation token">.</SPAN>popupEnabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// add the graphic to the graphics layer</SPAN> tempGraphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setActiveButton</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Are you placing your code at the beginning of the onclick functions?
Hi Robert,
Not quite sure where would be the best place to represent "stert sketching." I added the FeatureLayer popupEnabled = false to the onclick functions of each button in that SketchViewModel example. Then I change popupEnabled back to true in the on draw-complete function. It seems to work for line and polygon but isn't working for points.
Just disable the layers popup before you start sketching using the layers popupEnabled property.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#popupEnabled
