Here's an example of a mobile map package containing a map with a basemap layer. If I use the map directly, or copy the operational plus basemap layers to a new map, it will not render and hangs up. If I copy only the operational layers to a new map, the map will render.
Hi Mark,
Thanks for reporting this issue. I'm able to reproduce the issue with released versions of the API v100.x. While I am not sure what is causing the basemap layers to fail during load, the issue appears fixed in our current version. I can find out for you if there's a workaround for this.
Thanks for the info!
According to the developer who worked on the fix, you can do the following for the meantime:
To avoid the problem user can:Remove indexes for UUID fieldsUse fields of string type instead of UUID, if it is possible.
If you can find a workaround, that's great, but it's not a huge issue for me. Normally I only store operational layers in a mobile map package: I was just playing around with base layers to see how they worked.
