rows1 = arcpy.SearchCursor(fc, ["SHAPE@"]) extents = [] for row1 in rows1: ext = row1[0].extent extents.append(row1[0].extent) print(extents)
setValue is replaced by updateRow, I can't find reference to setValue in the new data access cursors...I rarely use them but the error says that you are trying to use a setValue method on a list object, suggesting that row is a list ... you need to define the rows to use in this line
with arcpy.da.UpdateCursor(input_shp,['FID','SHAPE@'])
which you haven't, and then reference the column by an offset number ie row[0] would be the FID field and row[1] the SHAPE@ field as in the example I sent you.Maybe someone who uses 'cursors' will weigh in...I have pretty well switched over to numpy arrays should I have the rare need to work with attributes.
cur.updateRow(row) doesn't work as well ?
# -*- coding: cp1252 -*- # Export zu rastercatalog.dbf # Autor Xander Bakker, Dan Patterson - vermurkst JB import arcpy, os, math from arcpy import env Fgdb = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster\RasterCatalog.gdb" arcpy.env.workspace = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster\RasterCatalog.gdb" # Ausgabepfad = (r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster").strip() Ausgabepfad = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster" ext = ".jpg" ## arcpy.AddField_management(Ausgabepfad + "\Orthos_Nummern.shp", "IMAGE", "TEXT", 100) # , "", "", "refcode", "NULLABLE", "REQUIRED") ext = ".jpg" fc = os.path.join(Ausgabepfad, "Orthos_Nummern.shp") fld_oid = "OBJECT_ID" # or: arcpy.Describe(fc).OIDFieldName fld_out = "IMAGE" # should exist in shapefile fld_xmin = "XMIN" arcpy.AddField_management(fc, "XMIN", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") arcpy.AddField_management(fc, "XMAX", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") arcpy.AddField_management(fc, "YMIN", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") arcpy.AddField_management(fc, "YMAX", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") def print_attributes(obj): for attr in arr.__dict__: print attr, getattr(arr, attr) input_shp = fc arr = arcpy.Array() with arcpy.da.UpdateCursor(input_shp,['FID','SHAPE@']) as cur: extents = [] for row in cur: ext = row[1].extent p0 = ext.lowerLeft; p1 = ext.upperRight print('Extent of shape... {}: '.format(row[0])) print(' X min/max {}, {}'.format(ext.XMin,ext.XMax)) Xmin = round((ext.XMin), 0) print (Xmin) print_attributes(row) row.setValue(fld_xmin, Xmin) print ( ' X min, {}'.format(ext.XMin)) cur.updateRow(row) print(' Y min/max {}, {}'.format(ext.YMin,ext.YMax)) arr.add(p0) arr.add(p1) mp = arcpy.Multipoint(arr) print('Extent of all {}'.format(mp.extent)) ##rows = arcpy.UpdateCursor(fc) ##for row in rows: ## fld_oid1 = int(row.getValue(fld_oid)) ## int_fld_oid1 = str(fld_oid1) ## # path = os.path.join(Ausgabepfad, "{0}{1}".format(row.getValue(fld_oid), ext)) ## path = os.path.join(Ausgabepfad, int_fld_oid1 + ext) ## print (path) ## path1 = str("" + path + "") ## row.setValue(fld_out, path) ## rows.updateRow(row)
Error:
Extent of shape... 0: X min/max 3510999.9998, 3511999.99983511000.0_arc_object <geoprocessing array object object at 0x02B88368>
Traceback (most recent call last): File "R:\Karto\zGIS\Python\exportrastercatalog.py", line 43, in <module> row.setValue(fld_xmin, Xmin)AttributeError: 'list' object has no attribute 'setValue'
Thought I wold get some information through def print attributes?
Your line numbers are off...any way
curs.updateRow(row) should be
cur.updateRow(row) there is no curs in the script you have shown
print_attributes(row) this function is define elsewhere?
you seem to be missing old cursors with new cursors, ie using setValue...you should be using updateRow as in the example here ie access the field by offset number for the row you are working with
Error message:
File "R:\Karto\zGIS\Python\exportrastercatalog.py", line 49, in <module>
Thats what I have so far with the help of dan and xander:
The goal is to create an oldschool image catalog as dbf, because we use a software which can't read the new ones.
import arcpy, os, math from arcpy import env Fgdb = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster\RasterCatalog.gdb" arcpy.env.workspace = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster\RasterCatalog.gdb" # Ausgabepfad = (r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster").strip() Ausgabepfad = r"R:\Karto\Bierer2014\Datenabgabe\20150113_Brandt\raster" ext = ".jpg" arcpy.AddField_management(Ausgabepfad + "\Orthos_Nummern.shp", "IMAGE", "TEXT", 100) # , "", "", "refcode", "NULLABLE", "REQUIRED") ext = ".jpg" fc = os.path.join(Ausgabepfad, "Orthos_Nummern.shp") fld_oid = "OBJECT_ID" # or: arcpy.Describe(fc).OIDFieldName fld_out = "IMAGE" # should exist in shapefile fld_xmin = "XMIN" arcpy.AddField_management(fc, "XMIN", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") arcpy.AddField_management(fc, "XMAX", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") arcpy.AddField_management(fc, "YMIN", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") arcpy.AddField_management(fc, "YMAX", "LONG", 7) # , "", "", "refcode", "NULLABLE", "REQUIRED") input_shp = fc arr = arcpy.Array() with arcpy.da.UpdateCursor(input_shp,['FID','SHAPE@']) as cur: extents = [] for row in cur: ext = row[1].extent p0 = ext.lowerLeft; p1 = ext.upperRight print('Extent of shape... {}: '.format(row[0])) print(' X min/max {}, {}'.format(ext.XMin,ext.XMax)) Xmin = round((ext.XMin), 0) print (Xmin) print_attributes(row) row.setValue(fld_xmin, Xmin) print ( ' X min, {}'.format(ext.XMin)) curs.updateRow(row) print(' Y min/max {}, {}'.format(ext.YMin,ext.YMax)) arr.add(p0) arr.add(p1) mp = arcpy.Multipoint(arr) print('Extent of all {}'.format(mp.extent)) rows = arcpy.UpdateCursor(fc) for row in rows: fld_oid1 = int(row.getValue(fld_oid)) int_fld_oid1 = str(fld_oid1) # path = os.path.join(Ausgabepfad, "{0}{1}".format(row.getValue(fld_oid), ext)) path = os.path.join(Ausgabepfad, int_fld_oid1 + ext) print (path) path1 = str("" + path + "") row.setValue(fld_out, path) rows.updateRow(row)
Thank you
Examine this
import arcpy input_shp = 'c:/folder/you_file_here.shp' arr = arcpy.Array() with arcpy.da.SearchCursor(input_shp,['FID','SHAPE@']) as cur: extents = [] for row in cur: ext = row[1].extent p0 = ext.lowerLeft; p1 = ext.upperRight print('Extent of shape... {}: '.format(row[0])) print(' X min/max {}, {}'.format(ext.XMin,ext.XMax)) print(' Y min/max {}, {}'.format(ext.YMin,ext.YMax)) arr.add(p0) arr.add(p1) mp = arcpy.Multipoint(arr) print('Extent of all {}'.format(mp.extent))
