I am trying to write to a graphic layer with a user map click.
Using a hit test and allowing the user to click counties in the map and writing them to a graphic layer
these are then seen displayed in the map as the user clicks on them
this seems to work fine
viewright<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
viewright<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitTest</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>screenPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> symbol <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-fill"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as new SimpleFillSymbol()</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">51</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">51</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">204</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.9</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"solid"</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"white"</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> selectionGraphic <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">;</SPAN>
selectionGraphic<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> symbol<SPAN class="punctuation token">;</SPAN>
resultsLayer4<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>selectionGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I then have a button that reads the Graphics Layer and tries to return the results.
<SPAN class="keyword token">var</SPAN> selectButton1 <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"select-by-polygon"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
selectButton1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addEventListener</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
viewright<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenLayerView</SPAN><SPAN class="punctuation token">(</SPAN>resultsLayer4<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>lyrView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
lyrView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"updating"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>val<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>val<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
lyrView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I am unsure if I am tackling this the right way....
I want the user to click the map and select counties and write them to a graphics layer.
I then need to read this graphics layer and get the unique id of each feature in the graphics layer.
QUESTIONS:
- Am I correctly writing to the Graphics Layer? Is there a better way to do this?
- Is there a better way to query the Graphics Layer to get a list of unique IDs from a Field value?
- Is there a way to click on a County that is already in the Graphics Layer and then remove it and have the blue graphic removed?
