Today I tested with an exported DWG from MicroStation and that drawing came in great in ArcGIS. All of the features came in as their respective Z shape types. Everything also came in with the Elevation attribute populated (including polygons and polylines; is that just the first vertex populating the field?). I also credit this thread for helping me:http://forums.arcgis.com/threads/51321-Model-error-Converting-CAD-to-FC?p=175387&posted=1#post175387Hopefully this may help someone else!
Thanks Chad,I'm having a similar problem, where the imported Polylines (either *.dgn or *.dwg) just brought into ArcMap show the Z value only of the first vertex. Do I have to convert all the lines to points, to get Z values at every vertices, does anyone know?Essentially what I'm getting is a CAD line representing the ground level and top of each tree, which they're hoping I can then auto generate the height based on the length of the line. However, the incoming polyline is the xy distance between the roots and the top of the tree, NOT the 3d distance between 2 z values.Is there a good way to import a 3d line? Or do I have to go to points and then work with those?Thanks,-tianna.dulmage
