I'm try to use token based authentication to get to my organisation portal on ArcGIS online using the ESRI ArcGISRuntime for .NET.
When trying to run the below code I get the following error.
Any help would be appreciated.
Code:
string uri = @"https://qgsp.maps.arcgis.com/sharing/rest";
"Starting credentials.");
var credentials = await IdentityManager.Current.GenerateCredentialAsync(uri, username, password) as ArcGISTokenCredential;
Error:
Unhandled Exception: System.AggregateException: One or more errors occurred. ---
> System.Net.Http.HttpRequestException: An error occurred while sending the requ
est. ---> System.Net.WebException: Unable to connect to the remote server ---> S
ystem.Net.Sockets.SocketException: A connection attempt failed because the conne
cted party did not properly respond after a period of time, or established conne
ction failed because connected host has failed to respond 50.17.189.113:443
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Sock
et s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state,
IAsyncResult asyncResult, Exception& exception)
--- End of inner exception stack trace ---
at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, Tr
ansportContext& context)
at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(IAsyncResult ar
at Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInterna
l.<SendAsync>d__2.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNot
ification(Task task)
at Esri.ArcGISRuntime.Security.ArcGISTokenWebRequest.<RequestTokenAsync>d__1.
MoveNext()
at Esri.ArcGISRuntime.Security.ArcGISTokenCredential.<GetArcGISTokenAsync>d__
d.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd(Task task)
at Esri.ArcGISRuntime.Security.ArcGISTokenCredential.<GenerateTokenImplAsync>
d__1.MoveNext()
at Esri.ArcGISRuntime.Security.TokenCredential.<GenerateTokenAsync>d__d.MoveN
ext()
at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
at DownloadSurvey.Program.<Login>d__3.MoveNext() in C:\Users\mccorkdm\documen
ts\visual studio 2015\Projects\DownloadSurvey\DownloadSurvey\Program.cs:line 39
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceled
Exceptions)
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotifica
tion)
at System.Threading.Tasks.Task`1.get_Result()
at DownloadSurvey.Program.Main(String[] args) in C:\Users\mccorkdm\documents\
visual studio 2015\Projects\DownloadSurvey\DownloadSurvey\Program.cs:line 22
