I'm using WAB developer edition v1.1. I have an AGOL web map that contains 6 feature service layers as well as 2 map services. Within AGOL I can edit all the feature services.
However, when I select the same AGOL web map to be used in WAB and I go to configure the Edit widget, the Edit widget says 'No editable feature layers are available'.
Ideas for why this is...?
My feature services are non-versioned. ArcGIS Server is 10.3. feature service SDE is 10.3, SQL Server 2014.
Thanks in advance!
