import numpy as np from osgeo import gdal #Load input Rasters (Basin Mask and Accumulated Upstream Area) #Input rasters need to be the same size f1 = gdal.Open("/pour_points/basins.asc") f2 = gdal.Open("/pour_points/source_area.asc") basins = np.array(f1.GetRasterBand(1).ReadAsArray()) areas = np.array(f2.GetRasterBand(1).ReadAsArray()) basins = np.ma.masked_values(basins,-9999) areas = np.ma.masked_values(areas,-9999) #Extract raster information (dimensions, min,max, etc) width = f1.RasterXSize height = f1.RasterYSize gt = f1.GetGeoTransform() res = gt[1] minx = gt[0] miny = gt[3] + width*gt[4] + height*gt[5] maxx = gt[0] + width*gt[1] + height*gt[2] maxy = gt[3] #Make arrays of lats and lons lons = np.linspace(minx,maxx-res,num=width) lats = np.linspace(maxy-res,miny,num=height) #Make arrays of same dimensions as input arrays of lat/lon values x,y = np.meshgrid(lons,lats) #Setup basin in/out arrays basin_ids = np.arange(np.min(basins),np.max(basins)) #Test basins = basin_ids = np.array([57087,53728,55400,37250,60966,71339]) basin = np.zeros(len(basin_ids),dtype='i') max_area = np.zeros(len(basin_ids),dtype='i') x_outlet = np.zeros(len(basin_ids),dtype='f') y_outlet = np.zeros(len(basin_ids),dtype='f') min_x = np.zeros(len(basin_ids),dtype='f') max_x = np.zeros(len(basin_ids),dtype='f') min_y = np.zeros(len(basin_ids),dtype='f') max_y = np.zeros(len(basin_ids),dtype='f') #Loop over every basin id, finding the maximum upstream area [and location] #and record the basin#,longitude,latitude,area for i,j in enumerate(basin_ids): #print 'i = ',i basin=np.int(j) x_basin = x[np.nonzero(basins==j)] y_basin = y[np.nonzero(basins==j)] max_area = np.int(max(areas[np.nonzero(basins==j)])) max_ind = np.argmax(areas[np.nonzero(basins==j)]) x_outlet = x_basin[max_ind] y_outlet = y_basin[max_ind] min_x = min(x_basin) max_x = max(x_basin)+res min_y = min(y_basin) max_y = max(y_basin)+res #save the list of pour points as a comma seperated text file # This file is directly importable into arcgis for validation purposes out_file = 'arctic_pour_points.txt' with file(out_file,'w') as outfile: outfile.write('OID,longitude,latitude,basin_area,min_lon,min_lat,max_lon,max_lat\n') np.savetxt(outfile,(np.array([basin,x_outlet,y_outlet,max_area,min_x,min_y,max_x,max_y]).T),delimiter=',')
