Hi,I just start learning 3D Analysist in ArcScene but got blocked by some problems: I am working on a file in which there is a layer of topography (TIN )and a layer of buildings.1. When I add the shapefile of buildings (the coordinates have Z values), they appear on the right location on the topography, however if I choose "floating on a custom surface" on the TIN layer in the layer properties, some of the building disappear. What is the reason?2. I extruded the buildings with extrusion of layer properties. But most of the buildings are extruded as only walls but not solid blocks. How can I solve the problem?3. How can I make a cross section from this 3D model? for example a section of a valley?4. Is there any way to export TIN or buildings into Sketchup/AutoCAD/3D Max? I found only "export scene" from "file"Thank you so much for answering these questions!
