Hello, I'm having troubles executing my QT app (that use Esri ArcGIS 100.7) on linux ubuntu.
Everything works fine when lauched from QtCreator but when I try to execute it from a terminal I have the following issue :
What am I doing wrong ?
Hi Quentin-
I believe if you include the PRI we ship with the SDK, everything should work. However, with this specific error, I think if you explicitly add the path to the libEsriCommonQt.so (/home/vagrant/arcgis/runtime_sdk/qt100.7/sdk/linux/x64/lib) to your LD_LIBRARY_PATH variable, everything should work.
