Hi,There are a few things to check:- When deploying your application, have you created an ArcGISRuntime deployment with the Deployment Builder? - The deployment needs to include the LocalServer option. - The deployment is contained within a folder such as "arcgisruntime10.2" which should be placed alongside your application executable- Relative paths to the map package (.MPK) are resolved relative to your application executable. - If you have chosen to reference the data when creating your Map Package you need to ensure that the same path is viable on your deployment machine (e.g. "C:\MyData\MapPackages\MyMapPackage.mpk").You can also use the Local Server Utility accessed from the Start Screen/Menu to enable logging in the ArcGIS Runtime LocalServer. If you want to enable logging in your deployment you can switch this on when using the Deployment Builder.CheersMike
Hi,The path is relative to executing application which by default might be in <project_name>\bin\debug. Therefore you'll need to take this into account, and ideally set the output folder for your application in the project settings to mimic your intended deployment structure.CheersMike
