//BEGIN CUSTOM FUNCTION FOR LAT-LONG DISPLAY function convertSP(uX,uY) { // Constants below from NAD 1983 State Plane Nevada West FIPS 2703(Feet). // From ArcMap layer properties. Coordinate system -> NV state plane -> modify // e_sqr is for NAD83 or GRS80 (http:en.wikipedia.org/wiki/NAD83#North_American_Datum_of_1983) var false_easting = (2624666 + (2/3)); // false easting var false_northing = (13123333 + (1/3)) // Should be 0. this is a 'fudge' factor. var a = 6378137.0 //Equatorial Radius (meters) For GRS80 var e_sqr = 0.006694300229 //Eccentricity of ellipsoid (GRS80) var lat_o = 34.75000000000 //Origin Latitude NV state plane var long_o = (118.58 + ((1/3) * 0.01)) // Central Meridan NV state plane var k_o = 0.99990000000000001 // Scale var pointx_ft = uX // number ft var pointx_ft = uX - false_easting // false easting accounted for. var pointy_ft = uY //number ft var pointy_ft = uY - false_northing // false northing accounted for. var e_sqr_2 = Math.pow(e_sqr, 2) // need this to calculate M var e_sqr_3 = Math.pow(e_sqr, 3) // need this to calculate M var radianlat_o = lat_o/(180/Math.PI) //degrees converted to radians 57.2957 var radianLong_o = long_o/(180/Math.PI) //degrees converted to radians var pointx_m = pointx_ft/3.2808399 var pointy_m = pointy_ft/3.2808399 var Mpart1_o = ((1-(e_sqr/4)-((3*e_sqr_2)/64)-((5*e_sqr_3)/256))*radianlat_o) var Mpart2_o = ((((3*e_sqr)/8)+((3*e_sqr_2)/32)+((45*e_sqr_3)/1024))*Math.sin(2*radianlat_o)) var Mpart3_o = ((((15*e_sqr_2)/256) + ((45*e_sqr_3)/1024))*4*Math.sin(4*radianlat_o) ) var Mpart4_o = ((35*e_sqr_3)/3072)*4*Math.sin(6*radianlat_o) var M_o = a*(Mpart1_o - Mpart2_o + Mpart3_o - Mpart4_o) var e_prim_sqr = e_sqr / (1 - e_sqr) var M = M_o + (pointy_m / k_o) var e1 = (1-Math.sqrt((1 - e_sqr))) / (1+Math.sqrt((1 - e_sqr))) //note: constant only for e_sqr of 0.00676866 var u = M / ( a*( 1-(e_sqr/4)- (3*(Math.pow(e_sqr,2)/64) - (5*(Math.pow(e_sqr,3)/256) ))) ) //radians var lat1_part1 = ((3 * (e1/2)) - (27 * (Math.pow(e1,3)/32) )) * Math.sin(2*u) var lat1_part2 = ((21 * (Math.pow(e1,2)/16)) - (55 * (Math.pow(e1,4)/32) )) * Math.sin(4*u) var lat1_part3 = ((151 * (Math.pow(e1,3)/96)) * Math.sin(6*u) ) var lat1_part4 = ((1097 * (Math.pow(e1,4)/512)) * Math.sin(8*u) ) var lat1 = u + lat1_part1 + lat1_part2 + lat1_part3 + lat1_part4 lat1 = lat1 * (180/Math.PI) var radian_lat1 = lat1/(180/Math.PI) //degrees converted to radians var C1 = e_prim_sqr * (0.5*(1 + Math.cos(2*radian_lat1))) var T1 = (1-Math.cos(2*radian_lat1))/(1+Math.cos(2*radian_lat1)) var N1 = a/(Math.sqrt(1-(e_sqr*0.5*(1-Math.cos(2*radian_lat1))))) var R1 = (a*(1-e_sqr))/ Math.sqrt(Math.pow((1-e_sqr * (0.5*(1 - Math.cos(2*radian_lat1))) ),3) ) var D = pointx_m/(N1*k_o) var Lat_final_part1 = lat1 var Lat_final_part2 = (N1 * (Math.tan(radian_lat1) / R1)) var Lat_final_part3 = Math.pow(D,2)/2 - ((( 5 + (3*T1) + (10*C1) - (4* Math.pow(C1,2)) - (9 * e_prim_sqr)) * Math.pow(D,4))/24) var Lat_final_part4 = ((61 + (90 * T1) + (298 * C1) + (45 * Math.pow(T1,2)) - (252 * e_prim_sqr) - (3 * Math.pow(C1,2)))* Math.pow(D,6))/720 var Lat_final = Lat_final_part1 - ((Lat_final_part2 *(Lat_final_part3 + Lat_final_part4)) * (180/Math.PI)) var Long_final_part1 = long_o var Long_final_part2 = D //D var Long_final_part3 = (((1 + (2*T1) + C1))* (Math.pow(D,3))) /6 var Long_final_part4 = 5 - (2 * C1) + (28*T1) - (3 * Math.pow(C1,2)) + (8 * e_prim_sqr) + (24 * Math.pow(T1,2)) Long_final_part4a = Long_final_part4 * (Math.pow(D,5) ) Long_final_part4b = Long_final_part4a /120 var Long_final = (-Long_final_part1 + (((Long_final_part2 - (Long_final_part3 + Long_final_part4b))) /Math.cos(radian_lat1)) * 180/Math.PI) // conversion to ddmmss Degreelat = Math.floor(Lat_final) Degreelong = (Math.floor(Long_final) + 1) //adjustment minlat = Math.floor(((Lat_final - Degreelat)*60)) minlong = Math.floor((((Long_final - Degreelong)*60))+ 1) seclat = Math.abs(((Lat_final - Degreelat - (minlat/60)) * 3600)) // - 1) seclong = Math.abs(((Long_final - Degreelong - (minlong/60)) * 3600 )) minlong = Math.abs(minlong); if (seclat >= 1) { seclat = (seclat -1); } else { seclat = (seclat + 59); minlat = (minlat -1) } seclat = seclat.toFixed(2); seclong = seclong.toFixed(2); var latitude = Lat_final.toString(); var longitude = Long_final.toString(); latitude = latitude.substr(0,10); longitude = longitude.substr(0,10); if (minlat<10) { minlat = "0" + minlat; } if (seclat<10) { seclat = "0" + seclat; } if (minlong<10) { minlong = "0" + minlong; } if (seclong<10) { seclong = "0" + seclong; } if (seclat == "60.00") { seclat = "00.00"; minlat = minlat +1; } if (seclong == "60.00") { seclong = "00.00"; minlong = minlong +1; } northing = uY.toFixed(0); easting = uX.toFixed(0); dojo.byId("coordDMS").innerHTML = " " + Degreelat + "°" + minlat + "\'" + seclat + "\"N " + (-Degreelong) + "°" + minlong + "\'" + seclong + "\"W "; dojo.byId("coordStPl").innerHTML = " Northing: " + northing + " Easting: " + easting + " "; } //END CUSTOM FUNCTION FOR LAT-LONG DISPLAY
I know this is and old post but thank you for sharing this code. I found it useful.
I converted your code/formulas above into T-sql functions, one for lat and one for long. Here is the latitude one in case anyone is interested for Florida State Plane East 0901 EPSG 2236:
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
Alter FUNCTION [dbo].[Langd_Convert_Feet_to_DecimalDegrees_Latitude]
-- Add the parameters for the function here
@y Numeric(38,8), -- latitude
@x Numeric(38,8) -- longitude
RETURNS Numeric(38,8)
AS
BEGIN
-- Constants below from NAD 1983 State Plane Florida East FIPS 0901(Feet).
-- e_sqr is for NAD83 or GRS80 (http:en.wikipedia.org/wiki/NAD83#North_American_Datum_of_1983)
/* From Esri WKT https://epsg.io/2236
PROJCS["NAD83_Florida_East_ftUS",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID
["GRS_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",24.33333333333333],PARAMETER["central_meridian",-81],
PARAMETER["scale_factor",0.999941177],PARAMETER["false_easting",656166.667],PARAMETER["false_northing",0],
UNIT["Foot_US",0.30480060960121924]]
Declare @false_easting Numeric(38,8) = 656166.667 -- original formula was (656166.6666666665 + (2/3)); -- false easting
Declare @false_northing Numeric(38,8) = 0 -- original formula was (0 + (1/3)) -- Should be 0. this is a 'fudge' factor.
Declare @a Numeric(38,8) = 6378137.0 --Equatorial Radius (meters) For GRS80
Declare @e_sqr Numeric(38,8) = 0.006694300229 --Eccentricity of ellipsoid (GRS80)
Declare @lat_o Numeric(38,8) = 24.33333333333333 --Origin Latitude FL state plane
Declare @long_o Numeric(38,8) = 81.0 -- original formula was (81.0 + ((1/3) * 0.01)) -- Central Meridan FL state plane, no negative sign for this formula
Declare @k_o Numeric(38,8) = 0.999941177 --0.9999411764705882 -- Scale factor
Declare @pointx_ft Numeric(38,8) = @x -- number ft
Set @pointx_ft = @x - @false_easting -- false easting accounted for.
Declare @pointy_ft Numeric(38,8) = @y --number ft
Set @pointy_ft = @y - @false_northing -- false northing accounted for.
Declare @e_sqr_2 Numeric(38,8) = power(@e_sqr, 2) -- need this to calculate M
Declare @e_sqr_3 Numeric(38,8) = power(@e_sqr, 3) -- need this to calculate M
Declare @radianlat_o Numeric(38,8) = @lat_o/(180/PI()) --degrees converted to radians 57.2957
Declare @radianLong_o Numeric(38,8) = @long_o/(180/PI()) --degrees converted to radians
Declare @pointx_m Numeric(38,8) = @pointx_ft/3.2808 --@pointx_ft/3.2808399
Declare @pointy_m Numeric(38,8) = @pointy_ft/3.2808 --@pointy_ft/3.2808399
Declare @Mpart1_o Numeric(38,8) = ((1-(@e_sqr/4)-((3*@e_sqr_2)/64)-((5*@e_sqr_3)/256))*@radianlat_o)
Declare @Mpart2_o Numeric(38,8) = ((((3*@e_sqr)/8)+((3*@e_sqr_2)/32)+((45*@e_sqr_3)/1024))*sin(2*@radianlat_o))
Declare @Mpart3_o Numeric(38,8) = ((((15*@e_sqr_2)/256) + ((45*@e_sqr_3)/1024))*4*sin(4*@radianlat_o) )
Declare @Mpart4_o Numeric(38,8) = ((35*@e_sqr_3)/3072)*4*sin(6*@radianlat_o)
Declare @M_o Numeric(38,8) = @a*(@Mpart1_o - @Mpart2_o + @Mpart3_o - @Mpart4_o)
Declare @e_prim_sqr Numeric(38,8) = @e_sqr / (1 - @e_sqr)
Declare @M Numeric(38,8) = @M_o + (@pointy_m / @k_o)
Declare @e1 Numeric(38,8) = (1-sqrt((1 - @e_sqr))) / (1+sqrt((1 - @e_sqr))) --note: constant only for @e_sqr of 0.00676866
Declare @u Numeric(38,8) = @M / ( @a*( 1-(@e_sqr/4)- (3*(power(@e_sqr,2)/64) - (5*(power(@e_sqr,3)/256) ))) ) --radians
Declare @lat1_part1 Numeric(38,8) = ((3 * (@e1/2)) - (27 * (power(@e1,3)/32) )) * sin(2*@u)
Declare @lat1_part2 Numeric(38,8) = ((21 * (power(@e1,2)/16)) - (55 * (power(@e1,4)/32) )) * sin(4*@u)
Declare @lat1_part3 Numeric(38,8) = ((151 * (power(@e1,3)/96)) * sin(6*@u) )
Declare @lat1_part4 Numeric(38,8) = ((1097 * (power(@e1,4)/512)) * sin(8*@u) )
Declare @lat1 Numeric(38,8) = @u + @lat1_part1 + @lat1_part2 + @lat1_part3 + @lat1_part4
Set @lat1 = @lat1 * (180/PI())
Declare @radian_lat1 Numeric(38,8) = @lat1/(180/PI()) --degrees converted to radians
Declare @C1 Numeric(38,8) = @e_prim_sqr * (0.5*(1 + cos(2*@radian_lat1)))
Declare @T1 Numeric(38,8) = (1-cos(2*@radian_lat1))/(1+cos(2*@radian_lat1))
Declare @N1 Numeric(38,8) = @a/(sqrt(1-(@e_sqr*0.5*(1-cos(2*@radian_lat1)))))
Declare @R1 Numeric(38,8) = (@a*(1-@e_sqr))/ sqrt(power((1-@e_sqr * (0.5*(1 - cos(2*@radian_lat1))) ),3) )
Declare @D Numeric(38,8) = @pointx_m/(@N1*@k_o)
Declare @Lat_final_part1 Numeric(38,8) = @lat1
Declare @Lat_final_part2 Numeric(38,8) = (@N1 * (tan(@radian_lat1) / @R1))
Declare @Lat_final_part3 Numeric(38,8) = power(@D,2)/2 - ((( 5 + (3*@T1) + (10*@C1) - (4* power(@C1,2)) - (9 * @e_prim_sqr)) * power(@D,4))/24)
Declare @Lat_final_part4 Numeric(38,8) = ((61 + (90 * @T1) + (298 * @C1) + (45 * power(@T1,2)) - (252 * @e_prim_sqr) - (3 * power(@C1,2)))* power(@D,6))/720
Declare @Lat_final Numeric(38,8) = @Lat_final_part1 - ((@Lat_final_part2 *(@Lat_final_part3 + @Lat_final_part4)) * (180/PI()))
Declare @Long_final_part1 Numeric(38,8) = @long_o
Declare @Long_final_part2 Numeric(38,8) = @D --D
Declare @Long_final_part3 Numeric(38,8) = (((1 + (2*@T1) + @C1))* (power(@D,3))) /6
Declare @Long_final_part4 Numeric(38,8) = 5 - (2 * @C1) + (28*@T1) - (3 * power(@C1,2)) + (8 * @e_prim_sqr) + (24 * power(@T1,2))
Declare @Long_final_part4a Numeric(38,8) = @Long_final_part4 * (power(@D,5) )
Declare @Long_final_part4b Numeric(38,8) = @Long_final_part4a /120
Declare @Long_final Numeric(38,8) = (-@Long_final_part1 + (((@Long_final_part2 - (@Long_final_part3 + @Long_final_part4b))) /cos(@radian_lat1)) * 180/PI())
RETURN @Lat_final
END
