It's not easy ... as you probably figured out based on the lack of responses 🙂It is however something we are thinking about adding to a future release of the Flex Viewer. So I just wanted to throw out some related questions:Would it be best (or at least good enough) if users could set the transparency on all operational layers (as opposed to them only being able to change the transparency on some of the operational layers)?Should this functionality (layer transparency for end-users) be the default?Should it always be there, or is something you would want to be able to turn off (not allowing your end users to change the transparency)?
It would be useful if the slider could be set passive (hiding) for separate layers.
Ryan, Finally found time to put this out there...http://www.arcgis.com/home/item.html?id=e2cb71d5c04d40d19e9f945ae0db7ce8
All,Have you seen the transparency slider on my site? You have to click the transparency icon on the map service in the TOC and then the slider replaces the layers name and has a close button to restore the name.http://gis.calhouncounty.org/flexviewer2.0/
Caution Rick,use it only for test, it is not well coded.Erwan
Can you try downloading it with a browser besides IE if that's what you tried?
... I think an alpha slider and a "zoom to layer" button would be interesting on top layers if they are checked as visible.codeErwan
