#assuming all features are single part!!! import arcpy lineFC = r"C:\temp\test.shp" dsc = arcpy.Describe(lineFC) shapeFieldName = dsc.ShapeFieldName featureNumber = 0 updateRows = arcpy.UpdateCursor(lineFC) for updateRow in updateRows:   vertexList = []   shapeObj = updateRow.getValue(shapeFieldName)   partObj = shapeObj.getPart(0)   for pointObj in partObj:      vertexList.append((pointObj.X, pointObj.Y))   vertexCount = len(vertexList)   if vertexCount < 3:      break #if only two verticies in the line, break the loop since there is no "angle" to calculate   i = 0 #   while i + 3 <= vertexCount: #that is until you run out of vertex triplicate pairs to count      x1 = vertexList[0]      y1 = vertexList[1]      x2 = vertexList[i + 1][0]      y2 = vertexList[i + 1][1]      x3 = vertexList[i + 2][0]      y3 = vertexList[i + 2][1]      funkyStat = (x1 + y2) / 1.61803399 #blah blah whatever formula      i = i + 1   updateRow.FUNKY_STAT = funkyStat   updateRows.updateRow(updateRow) del updateRow, updateRows
Very nice - This is actually quite usefull to me - I have done some projects in the past doing network anaylysis on logging roads... And I was looking for a way to apply some factors that would describe how "difficult" the road is to manuver (road type as well as each segment's vertical/horizontal complexity). When I get back to my routing project (months away), I'll try to post some code that uses z values as well. Thanks for posting the code...
Maybe a newbie question, but i didn't find any solution yet - Is it possible to add field into fc (with fieldName as a variable) and the to use something like updateRow.fieldName? (if using posted script, it is necessary to have "pre-added" fields - it would be much easier to add them in the beginning of the script...) Thanks!
field1 = "FIELD1" field2 = "FIELD2" updateRows = arcpy.UpdateCursor(fc) for updateRow in updateRows: Â Â field1Value = updateRow.getValue(field1) Â Â updateRow.setValue(field2, field1Value / 2) Â Â updateRows.updateRow(updateRow) del updateRow, updateRows
# # This script calculates average "curvature" of roads # # It takes a line feature class (with pre-added fields "angleChng" and "AvCurv"!) # then takes the fist line # then takes first three verticies # and calculates the angular change of line between those three verticies # then it loops through all verticies of the line, calculates angular changes and cumulates them # after going through whole line, it writes down the total angular change, calculates and writes down the average curvature # and then this is repeated for all lines in the feature class # import arcpy, math, datetime, numpy from arcpy import env print "starting" start = datetime.datetime.now() # for calculating time of process lineFC = r"roads.shp" # input fc - with pre-added fields "angleChng" and "AvCurv"! dsc = arcpy.Describe(lineFC) shapeFieldName = dsc.ShapeFieldName updateRows = arcpy.UpdateCursor(lineFC) for updateRow in updateRows: # looping through lines   vertexList = []   shapeObj = updateRow.getValue(shapeFieldName)   partObj = shapeObj.getPart(0)   for pointObj in partObj:      vertexList.append((pointObj.X, pointObj.Y)) # getting coordinates of all line vertices   vertexCount = len(vertexList)   i = 0   angularChange=0   averageCurvature=0   while i + 3 <= vertexCount: # that is until you run out of vertex triplicate pairs to count      x1 = vertexList[0] # coordinates of three vertices      y1 = vertexList[1]      x2 = vertexList[i + 1][0]      y2 = vertexList[i + 1][1]      x3 = vertexList[i + 2][0]      y3 = vertexList[i + 2][1]      u1=x1-x2 # vectors (BA and BC !)      u2=y1-y2      v1=x3-x2      v2=y3-y2      cit=(u1*v1)+(u2*v2) # calculating the angle of vectors      jmen1=math.sqrt((u1*u1)+(u2*u2))      jmen2=math.sqrt((v1*v1)+(v2*v2))      jmen=jmen1*jmen2      cosfi=cit/jmen      fiRad=numpy.arccos(cosfi) # angle of vectors [rad]      fiGrad=fiRad*200/math.pi      fiGrad=200-fiGrad # angle change of one segment of line [grad]      angularChange=angularChange+fiGrad # total angle change of line      i = i + 1   averageCurvature=angularChange/shapeObj.length*1000 # average curvature of line = angle change in one kilometer   updateRow.angleChng=angularChange # adding angle change of line   updateRow.AvCurv=averageCurvature # adding average curvature of line   updateRows.updateRow(updateRow) print "Done in ",datetime.datetime.now() - start, " seconds" del updateRows, updateRow, lineFC
Sure you can do it in the cursor... I guess an update cursor so you could then populate your angle statistic field value, right?It'd look something like this then:...
#assuming all features are single part!!! import arcpy fcVertexList = [] lineFC = r"C:\temp\test.shp" dsc = arcpy.Describe(lineFC) shapeFieldName = dsc.ShapeFieldName featureNumber = 0 searchRows = arcpy.SearchCursor(lineFC) for searchRow in searchRows: Â Â featureNumber = featureNumber + 1 Â Â fcVertexList.append([]) Â Â shapeObj = searchRow.getValue(shapeFieldName) Â Â partObj = shapeObj.getPart(0) Â Â for pointObj in partObj: Â Â Â Â Â fcVertexList[featureNumber - 1].append([pointObj.X, pointObj.Y])
