The ScaleLine really seems to be a step backwards. Is there any way (i.e. an ACTUAL EXAMPLE) to get it to look and behave the way the ScaleBar did?
<Style x:Key="ScaleBarStyle" TargetType="esri:ScaleLine"> <Setter Property="Background" Value="White"/> <Setter Property="TargetWidth" Value="150.0"/> <Setter Property="FontSize" Value="10.0"/> <Setter Property="Foreground" Value="Black"/> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="esri:ScaleLine"> <StackPanel Name="LayoutRoot" Orientation="Horizontal"> <Grid VerticalAlignment="Center" Height="10" Width="{Binding MetricSize, RelativeSource={RelativeSource TemplatedParent}}"> <Grid.ColumnDefinitions> <ColumnDefinition Width="1*"/> <ColumnDefinition Width="1*"/> <ColumnDefinition Width="1*"/> <ColumnDefinition Width="2*"/> <ColumnDefinition Width="5*"/> </Grid.ColumnDefinitions> <Grid.RowDefinitions> <RowDefinition Height="1*"/> <RowDefinition Height="1*"/> </Grid.RowDefinitions> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="0" Grid.Column="0"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="0" Grid.Column="1"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="0" Grid.Column="2"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="0" Grid.Column="3"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="0" Grid.Column="4"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="1" Grid.Column="0"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="1" Grid.Column="1"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="1" Grid.Column="2"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="1" Grid.Column="3"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="1" Grid.Column="4"/> </Grid> <TextBlock Text="{Binding MetricValue, RelativeSource={RelativeSource TemplatedParent}}" VerticalAlignment="Center" Margin="2,0"/> <TextBlock Text="{Binding MetricUnit, RelativeSource={RelativeSource TemplatedParent}}" VerticalAlignment="Center"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> </Style>
<esri:ScaleLine Map="{Binding ElementName=MyMap}" Margin="10" HorizontalAlignment="Left" VerticalAlignment="Bottom" Style="{StaticResource ScaleBarStyle}" />
One more question: how do I control the units it displays? I can set english vs. metric, but what if I always want it to display feet?
private void UnitCombo_SelectionChanged(object sender, SelectionChangedEventArgs e) { if (SetUnitBorder.Visibility == System.Windows.Visibility.Visible) { string _unit = UnitsCombo.SelectedItem.ToString(); if (_unit == "FEET") MyScaleBar.DisplayUnit = ScaleBarUnit.Feet; else if (_unit == "MILES") MyScaleBar.DisplayUnit = ScaleBarUnit.Miles; else if (_unit == "METERS") MyScaleBar.DisplayUnit = ScaleBarUnit.Meters; else if (_unit == "KILOMETERS") MyScaleBar.DisplayUnit = ScaleBarUnit.Kilometers; } }
Yes, this was marked obsolete in 2.2 when ScaleLine was introduced: http://help.arcgis.com/en/webapi/silverlight/2.2/help/index.html#/What_s_new_in_2_2/0166000000m2000000/ and deprecated in 2.3: http://help.arcgis.com/en/webapi/silverlight/help/index.html#//0166000000mm000000
I really need feet all the time.
Yes, you can get it to look as the ScaleBar. The old scalebar style is just a particular case of the new scaleline control.The sample is given in the documentation.Define a scaleline style such as : <Style x:Key="ScaleBarStyle" TargetType="esri:ScaleLine"> <Setter Property="Background" Value="White"/> <Setter Property="TargetWidth" Value="150.0"/> <Setter Property="FontSize" Value="10.0"/> <Setter Property="Foreground" Value="Black"/> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="esri:ScaleLine"> <StackPanel Name="LayoutRoot" Orientation="Horizontal"> <Grid VerticalAlignment="Center" Height="10" Width="{Binding MetricSize, RelativeSource={RelativeSource TemplatedParent}}"> <Grid.ColumnDefinitions> <ColumnDefinition Width="1*"/> <ColumnDefinition Width="1*"/> <ColumnDefinition Width="1*"/> <ColumnDefinition Width="2*"/> <ColumnDefinition Width="5*"/> </Grid.ColumnDefinitions> <Grid.RowDefinitions> <RowDefinition Height="1*"/> <RowDefinition Height="1*"/> </Grid.RowDefinitions> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="0" Grid.Column="0"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="0" Grid.Column="1"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="0" Grid.Column="2"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="0" Grid.Column="3"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="0" Grid.Column="4"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="1" Grid.Column="0"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="1" Grid.Column="1"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="1" Grid.Column="2"/> <Rectangle Fill="{TemplateBinding Foreground}" Grid.Row="1" Grid.Column="3"/> <Rectangle Fill="{TemplateBinding Background}" Grid.Row="1" Grid.Column="4"/> </Grid> <TextBlock Text="{Binding MetricValue, RelativeSource={RelativeSource TemplatedParent}}" VerticalAlignment="Center" Margin="2,0"/> <TextBlock Text="{Binding MetricUnit, RelativeSource={RelativeSource TemplatedParent}}" VerticalAlignment="Center"/> </StackPanel> </ControlTemplate> </Setter.Value> </Setter> </Style> Then you can use it with code like : <esri:ScaleLine Map="{Binding ElementName=MyMap}" Margin="10" HorizontalAlignment="Left" VerticalAlignment="Bottom" Style="{StaticResource ScaleBarStyle}" /> and you get this kind of scaleline:
