Using jsapi 3.2 and server 10.11, running a simple intersection queryTask on a polygon AGSDynamicService, see below, and it fails half of the time with HTTP 200 and response payload {"error":{"code":400,"message":"Unable to complete operation.","details":[]}}Has anyone been having a similar problem? Do these Etags make sense? I'm keying in on the Etag strangeness because it seems like I should be getting 304 not modifieds when Etags are available or at least the whole response again -- not errors.
var query = new esri.tasks.Query(),
queryTask = new esri.tasks.QueryTask(SERVICE_PATH_OPERATIONAL_MAP);
query.geometry = mapPoint;
query.outFields = ["DAC", "MHI", "GEOID10"];
queryTask.execute(query, function (res) {
//do something
}, function (err) {
alert(err.message);
Here's the series of events:----------------------------1. Clear browser cache2. a. Send request with query b. Get 200 response with GOOD answer and Etag 13468829923. a. Send request with same query and If-None-Match 1346882992 b. Get 200 response with ERROR answer and Etag bdb512714. a. Send request with same query and If-None-Match bdb51271 b. Get 200 response with GOOD answer and Etag 13468829925. a. Send request with same query and If-None-Match 1346882992 b. Get 200 response with ERROR answer and Etag bdb512716. a. Send request with same query and If-None-Match bdb51271 b. Get 200 response with GOOD answer and Etag 13468829927. a. Send request with same query and If-None-Match 1346882992 b. Get 200 response with ERROR answer and Etag bdb51271 Using wikipedia for how Etags should generally work? http://en.wikipedia.org/wiki/HTTP_ETagThanks for your help!
