Hello everyone,
Anyone can share a source code in C# or VB.Net about how to connect to ArcGIs Server.
I have a code that was working in 10.0 but it does not work anymore.
Thank you.
I just want to re-write this VB.Net code using ArcGIS Server 10.2. It works fine in ArcGIS Server 10.0 but it fails in ArcGIS Server 10.2:
Dim gputilities As IGPUtilities = New GPUtilitiesClass()
Dim myResult As Boolean = True
' Declare server context variables Dim mapServerContext As IServerContext = Nothing
Dim agsServerConnection As ESRI.ArcGIS.ADF.Connection.AGS.AGSServerConnection = Nothing
Dim featuresCount As Integer
Try
Dim username As String = ConfigurationManager.AppSettings("username") Dim password As String = ConfigurationManager.AppSettings("password") Dim domain As String = ConfigurationManager.AppSettings("domain") Dim hostname As String = ConfigurationManager.AppSettings("hostname") Dim mapservice As String = ConfigurationManager.AppSettings("mapservice")
' Connect to ArcGIS Server Dim adfIdentity As New ESRI.ArcGIS.ADF.Identity(username, password, domain) agsServerConnection = New ESRI.ArcGIS.ADF.Connection.AGS.AGSServerConnection(hostname, adfIdentity) agsServerConnection.Connect()
If (Not agsServerConnection.IsConnected) Then
agsServerConnection.Dispose() Return False
End If
' Get a reference to the server object manager to use in creating server objects Dim serverObjectManager As ESRI.ArcGIS.Server.IServerObjectManager = agsServerConnection.ServerObjectManager
' Create a server context for and get a reference to the BloomfieldTownship map service. We will ' use this to access map information and query features. mapServerContext = serverObjectManager.CreateServerContext(mapservice, "MapServer")
Dim mapServer As ESRI.ArcGIS.Carto.IMapServer2 = TryCast(mapServerContext.ServerObject, ESRI.ArcGIS.Carto.IMapServer2)
' Get a reference to the map service's server objects
Dim mapServerObjects As ESRI.ArcGIS.Carto.IMapServerObjects = CType(mapServer, ESRI.ArcGIS.Carto.IMapServerObjects)
Dim map As ESRI.ArcGIS.Carto.IMap = mapServerObjects.Map(mapServer.DefaultMapName)
from 10.0 to 10.1 there was a huge change on how to access ArcGIS Server... Local connections (AGSConnection()) are no more... I am sure you have found that out.
As per others questions, it depends on what you are looking for.
It is through the REST/SOAP service API?
Is it to create SOIs or SOEs ? ( Server object interceptors / Server object extensions )
Hi Jose,
Depends on what you mean by connect I suppose. I put two samples below that should work. Once simply adding the ArcGIS Server layer to a current map view, and another querying against an ArcGIS Server layer.
//Add a new dynamic map service layer. Replace the URL with your desired ArcGIS Server rest URL.
//Use ArcGISTiledMapServiceLayer if it is a tile map service instead.
var layer = new ArcGISDynamicMapServiceLayer(new Uri("http://MyServer/arcgis/rest/services/MyService/MapServer"));
await layer.InitializeAsync();
//add the layer to the map and zoom to its extent
this.MyMapView.Map.Layers.Add(layer);
If by connect you mean you just want to query against the layer, then you'll want to use a QueryTask.
QueryTask myQueryTask = new QueryTask(new Uri("http://MyServer/arcgis/rest/services/MyService/MapServer/0"));
Query myQuery = new Query("OBJECTID < 100");
OrderByField myOrder = new OrderByField("OBJECTID", SortOrder.Ascending);
myQuery.OrderByFields.Add(myOrder);
myQuery.ReturnGeometry = true;
myQuery.OutFields.Add("OBJECTID");
myQuery.OutFields.Add("GLOBALID");
QueryResult myResult = await myQueryTask.ExecuteAsync(myQuery);
I believe you have to do it through map services. After searching for a long time I found this
Supported geodatabase formats—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
which says
ArcGIS Runtime for .NET against Enterprise geodatabase -> Supported only if using services
I hope someone proves me wrong.
I can't answer your question...but tagging ArcGIS Runtime SDK for .NET for more exposure.
Can you be more specific as to what you're trying to do? For instance, this page - Use a MapView to display a map—ArcGIS Runtime SDK for .NET | ArcGIS for Developers - describes how to display a map using the runtime SDK. If you notice, there are service URIs for tiled map services and also feature layers, e.g. http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/EarthquakesFromLastSevenDays/MapServer/0"/
That's a connection to ArcGIS Server...
Runtime SDK.
Are you looking to interface with server through the web or through runtime SDK?
