I tried a query and on web-query for tests purpose and it's working, like: http://is.bramar.net/arcgis/rest/services/SocioEconomics/OutrogasAESA_FS/FeatureServer/0/query?where=1+%3D+1&objectIds=&…
In android it is not working.
My code:
compile 'com.esri.arcgis.android:arcgis-android:10.2.9'
featureLayer = new ArcGISFeatureLayer(
"http://is.bramar.net/arcgis/rest/services/SocioEconomics/OutrogasAESA_FS/FeatureServer"
, MODE.ONDEMAND);
and
mapView.setOnSingleTapListener(new OnSingleTapListener() {
public void onSingleTap(float x, float y) {
Geometry geom = (GeometryEngine.buffer(pointClicked, mapView.getSpatialReference(), 100, null));
// build a query to select the clicked feature
Query query = new Query();
query.setOutFields(new String[]{"*"});
query.setSpatialRelationship(SpatialRelationship.ENVELOPE_INTERSECTS);
query.setGeometry(geom);
query.setInSpatialReference(mapView.getSpatialReference());
featureLayer.selectFeatures(query, ArcGISFeatureLayer.SELECTION_METHOD.NEW, new CallbackListener<FeatureSet>() {
// handle any errors
public void onError(Throwable e) {
Log.d(TAG, "Select Features Error" + e.getLocalizedMessage());
public void onCallback(FeatureSet queryResults) {
int size = 0;
if (!Utils.isNullOrEmpty(queryResults.getGraphics())) {
size = queryResults.getGraphics().length;
Utils.log("Size: " + size);
if (size > 0) {
Log.d(TAG, "Feature found id=" + queryResults.getGraphics()[0].getAttributeValue(featureLayer.getObjectIdField()));
// set new data and notify adapter that data has changed
listAdapter.setFeatureSet(queryResults);
listAdapter.notifyDataSetChanged();
// This callback is not run in the main UI thread. All GUI
// related events must run in the UI thread,
// therefore use the Activity.runOnUiThread() method. See
// http://developer.android.com/reference/android/app/Activity.html#runOnUiThread(java.lang.Runnable)
// for more information.
AttributeEditorActivity.this.runOnUiThread(new Runnable() {
public void run() {
// show the editor dialog.
showDialog(ATTRIBUTE_EDITOR_DIALOG_ID);
