Hi all,
I can't seem to get the attached CSV data points (which are Decimal Degree coordinates) to display on my map file (also attached). I've tried playing around with the long/lat columns, changing the projected system, and all to no avail. Really quite stuck now, so would be very grateful for some clarity as to where I'm going wrong.
Thanks!
Calum
Hi abdallah_91@yahoo.com
Apologies for my delay in replying. Unfortunately, this still isn't working. In terms of what I've done, I have:
1) Imported the geographic entity (here, OA layer)
2) Added data (XY data) and defined the Long/Lat
3) Ensured that the projections are the same (using the Project tool)
However, the data does not display at all. What else could be happening here?
Thanks again for all of your help! It's really appreciated.
After you add points layer and define its spatial reference well, use Project—Help | ArcGIS Desktop tool for this layer to be same the 'OA' layer projection .
Hi Abdullah,
Thanks for the quick reply, and it's encouraging that you've got it working! I'm trying to display the points on top of the 'OA' layer in the main file (OAs are geographic areas, these ones focused on London). Are you able to do this at all? I've followed numerous tutorials, but without success, so I'd be really grateful if you could walk through how to do this.
Thanks again!
I tried your data. and I have not any problem.
