When I try to save my story map tour I get red message "Save failed. Please try again".
This drives me nuts and I usually have to start my map tour over again. ESRI? bug? Can you offer some advice?
Thank you.
HI Andrea, sorry about your issues.
If your network connection is working fine it must be a bug.
Do you see this happening after a specific set of actions in the builder?
One advice I can give: it may be because you are entering some text content that the application doesn't know how to deal with. This can happen for exemple if you copy/paste content or try to create html tags. Are you doing any of this?
It's usually when I'm trying to delete pictures "tour points" or add more or rearrange them. Especially when I first create the map story tour from my web map and I don't have the first layer as my tour points. My pictures are on Picasa so I have to create the story map tour app from my web map without a picture layer. It really doesn't like that and freaks out the app. If I start the other way: from the Story Map Tour | Story Maps it asks me first where my pictures are located. This is great BUT this second approach doesn't let me use my own web map. So I have to do a work around to get it to work. Have you noticed this?
Thanks, this has never been reported, we will look if we can reproduce the issue.
When you create the tour from StoryMaps website, a webmap is created behind the scene for you. You can find it though "My Content" in ArcGIS Online and modify it to include layers. This should not change anything regarding your first issue but I thought I would just precise that.
Ah, ok this is probably the best way to create the story map tour then. Create the tour from the StoryMaps website and then add layers to the webmap that is added behind the scenes, as you described. I didn't fully realize I could do that, so thank you.
As I stated above, creating the Story Map Tour from the already created webmap doesn't work very well if you are importing pictures from online since it looks for the first layer as the picture layer automatically. Probably should change the way that works so it asks the user instead of automatically assuming.
Thanks.
has this issue ever been resolved? I am trying to add a location to use as my overview (first slide) and every time I try to save I cannot. I am using a web map I created w/ a hosted (my server) feature service as my tour point layer. I really do not want to have to create something at the story maps page just because my already-created web map is not working....seems like things should work the same anywhere. Between this and the map not able to zoom to my tour locations it doesn't really seem like a very good solution for me so far.
I was having this issue as well, and called to support. They referred me to forgo using my own server and instead hosting it online(in the cloud).
This is still an issue in 2019. I was making a Story Map Tour, and I am unable to share my progress with my colleagues, since it will not save changes. The map data is hosted on AGOL, while the images are hosted on Amazon S3.
In general, I would lobby for more useful error codes. Perhaps my photos are still to large? I guess I'll try re-uploading smaller versions. But will they be small enough? Who knows? What is the ideal size? Maybe the photos aren't the problem, but somebody on Stack Exchange found that to be their issue. But regardless, Esri's fail codes are notoriously useless.
I'll be sure to update if that happens to work.
Reduced file size of the thumbnails seems to help. I used a max dimension of 500 px. The images seem a bit dulled by the process, but I am at least able to save my changes.
