package com.main.utilinspect; import java.io.File; import java.io.FileNotFoundException; import java.io.IOException; import java.io.RandomAccessFile; import org.codehaus.jackson.JsonNode; import org.codehaus.jackson.map.ObjectMapper; import android.content.Context; import android.util.Log; import android.database.Cursor; import android.database.sqlite.SQLiteDatabase; import com.esri.android.map.TiledServiceLayer; import com.esri.core.geometry.Envelope; import com.esri.core.geometry.Point; import com.esri.core.geometry.SpatialReference; public class OfflineDbTiledLayer extends TiledServiceLayer { File workingDirectory; String mapDefinition; String databaseName; private SQLiteDatabase database; File blankImage; byte[] blankImageBytes; private final Object lock = new Object(); private static final String TAG = "OfflineTiledLayer"; public OfflineDbTiledLayer(Context paramContext, File workingDirectory, String mapDefinition, String databaseName) { super("required"); this.workingDirectory = workingDirectory; this.mapDefinition = mapDefinition; this.databaseName = databaseName; String databasePath = workingDirectory.getAbsolutePath() + File.separator + databaseName; this.database = SQLiteDatabase.openDatabase(databasePath, null, SQLiteDatabase.NO_LOCALIZED_COLLATORS); this.blankImage = new File(workingDirectory.getAbsolutePath() + File.separator + "blank.png"); RandomAccessFile raFile = null; try { raFile = new RandomAccessFile(this.blankImage, "r"); blankImageBytes = new byte[(int) raFile.length()]; raFile.readFully(blankImageBytes); } catch (FileNotFoundException e) { // TODO Auto-generated catch block e.printStackTrace(); } catch (IOException e) { // TODO Auto-generated catch block e.printStackTrace(); } finally { if(raFile != null) { try { raFile.close(); } catch (IOException e) { // TODO Auto-generated catch block e.printStackTrace(); } } } try { ObjectMapper m = new ObjectMapper(); JsonNode root = m.readTree(new File(workingDirectory.getAbsolutePath() + File.separator + mapDefinition)); JsonNode tileInfo = root.get("tileInfo"); double x = tileInfo.get("origin").get("x").asDouble(); double y = tileInfo.get("origin").get("y").asDouble(); Point origin = new Point(x, y); int dpi = tileInfo.get("dpi").asInt(); int width = tileInfo.get("rows").asInt(); int height = tileInfo.get("cols").asInt(); JsonNode lods = tileInfo.get("lods"); int levels = lods.size(); double resolutions[] = new double[levels]; double scales[] = new double[levels]; for(int i = 0; i < levels; i++) { JsonNode level = lods.get(i); resolutions = level.get("resolution").asDouble(); scales = level.get("scale").asDouble(); } int wkid = tileInfo.get("spatialReference").get("wkid").asInt(); JsonNode initialExtent = root.get("initialExtent"); Envelope initialExtentEnvelope = new Envelope( initialExtent.get("xmin").asDouble(), initialExtent.get("ymin").asDouble(), initialExtent.get("xmax").asDouble(), initialExtent.get("ymax").asDouble() ); JsonNode fullExtent = root.get("fullExtent"); Envelope fullExtentEnvelope = new Envelope( fullExtent.get("xmin").asDouble(), fullExtent.get("ymin").asDouble(), fullExtent.get("xmax").asDouble(), fullExtent.get("ymax").asDouble() ); setDefaultSpatialReference(SpatialReference.create(wkid)); setInitialExtent(initialExtentEnvelope); setFullExtent(fullExtentEnvelope); setTileInfo(new TileInfo(origin, scales, resolutions, levels, dpi, width, height)); } catch(Exception ex){ } super.initLayer(); return; } private void openDatabase(){ if(!database.isOpen()){ String databasePath = workingDirectory.getAbsolutePath() + File.separator + databaseName; this.database = SQLiteDatabase.openDatabase(databasePath, null, SQLiteDatabase.NO_LOCALIZED_COLLATORS); } } private void closeDatabase(){ if(database.isOpen()){ this.database.close(); } } @Override protected byte[] getTile(int level, int column, int row) throws Exception { byte[] tileImage; Log.i(TAG, "getTile"); Log.i(TAG, "getTile - retrieving tile"); synchronized(lock) { Log.i(TAG, "getTile - entered synchronized block - thread " + Integer.toString(android.os.Process.myTid())); openDatabase(); // First check to see if the tile exists in the database Cursor tileCursor = database.rawQuery("SELECT image FROM tiles WHERE level = " + Integer.toString(level) + " AND row = " + Integer.toString(row) + " AND column = " + Integer.toString(column), null); if(tileCursor != null && tileCursor.getCount() > 0) { tileCursor.moveToFirst(); tileImage = tileCursor.getBlob(0); Log.i(TAG, "getTile - tile found, returning image"); } else { // The tile does not exist in the database, read the blank placeholder tile and serve it tileImage = blankImageBytes; Log.i(TAG, "getTile - tile not found returning blank"); } tileCursor.close(); //this.database.close(); } Log.i(TAG, "getTile - exited synchronized block"); return tileImage; } }
