<?xml version="1.0" ?> <!-- encoding="UTF-8" --> <configuration> <identifylayeroption>visible</identifylayeroption> <identifytolerance>10</identifytolerance> <defaultzoomscale>5000</defaultzoomscale> <keepidentifyactive>true</keepidentifyactive> <returngeometryforzoom>true</returngeometryforzoom> <enablelineselect>true</enablelineselect> <enableextentselect>true</enableextentselect> <enablepolyselect>true</enablepolyselect> <enablecircleselect>true</enablecircleselect> <enableellipseselect>true</enableellipseselect> <enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo> <enablemouseoverrecordinfo>true</enablemouseoverrecordinfo> <enablegraphicclickinfo>true</enablegraphicclickinfo> <usemaptime>false</usemaptime> <infoautoclosemilliseconds>2000</infoautoclosemilliseconds><!-- 2 seconds --> <autoactivatedtool>mappoint</autoactivatedtool><!-- possible values are extent or polygon or mappoint or polyline or nothing --> <excludebasemaps>true</excludebasemaps> <disablepopuplinks>false</disablepopuplinks> <disablelayerdropdown>false</disablelayerdropdown> <disablealllayerschoice>false</disablealllayerschoice> <replacenullswithemptystring>true</replacenullswithemptystring> <labels> <zoom2message>Click to Zoom to Point</zoom2message> <identifylabel>Identify</identifylabel> <resultslabel>Results</resultslabel> <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel> <pointlabel>Identify by Point</pointlabel> <linelabel>Identify by Polyline</linelabel> <rectlabel>Identify by Rectangle</rectlabel> <polylabel>Identify by Polygon</polylabel> <circlelabel>Identify by Circle</circlelabel> <ellipselabel>Identify by Ellipse</ellipselabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> <removeresultmessage>Remove Result</removeresultmessage> <idfrom>Identify From</idfrom> <noresultsfoundlabel>No Results Found</noresultsfoundlabel> <resultsfoundlabel>Results Found</resultsfoundlabel> <alllayers>All Layers</alllayers> <layersremaining>layers remaining:</layersremaining> </labels> <useproxy><!-- Enter the label of the MapService from the main config.xml --> <!--<proxymapservice label="Imagery" /> <proxymapservice label="Streets" /> --> </useproxy> <!-- Sewer Layers --> <layers onlythese="true"> <!-- <excludelayer name="AerialHybrid_2009" /> --> <!-- <excludelayer name="AerialHybrid_2011" /> --> <!-- <excludelayer name="AerialLayer_2009" /> --> <!-- <excludelayer name="AerialLayer_2011" /> --> <!-- <excludelayer name="BaseLayers" /> --> <!-- <excludelayer name="Routes" /> --> <!-- <excludelayer name="Notifications" /> --> <!-- <excludelayer name="CostSharingLayers" /> --> <layer> <name>Sewer Manhole</name> <id>11</id> <url>http://server/svr/rest/services/UtilityLayers/MapServer</url> <fields all="false"> <field name="Rim elevation" /> <field name="As-built #" /> <field name="As-built link" popuponly="true" /> <field name="Manhole # (as-built)" /> <field name="Status" /> <field name="Owned and maintained by" /> <field name="Comments" /> </fields> <layer> <name>Sewer Tee, Tap or Cross</name> <id>18</id> <url>http://server/svr/rest/services/UtilityLayers/MapServer</url> <fields all="false"> <field name="Type of fitting" /> <field name="Size" /> <field name="Material" /> <field name="As-built #" /> <field name="As-built link" popuponly="true" /> <field name="Status" /> <field name="Owned and maintained by" /> <field name="Comments" /> </fields> <links> <link includeinresults="false" field="As-built link" alias="Copy As-built" tooltip="Copy As-built"> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix>assets/images/dwgIcon.png</iconsuffix> </link> </links> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Sewer Locate Wire</name> <id>20</id> <url>http://server/svr/rest/services/UtilityLayers/MapServer</url> <fields all="false"> <field name="Type of locate device" /> <field name="As-built #" /> <field name="As-built link" popuponly="true" /> <field name="Owned and maintained by" /> <field name="Comments" /> </fields> <links> <link includeinresults="false" field="As-built link" alias="Copy As-built" tooltip="Copy As-built"> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix>assets/images/dwgIcon.png</iconsuffix> </link> </links> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Gravity Main</name> <id>29</id> <url>http://server/svr/rest/services/UtilityLayers/MapServer</url> <fields all="false"> <field name="Size" /> <field name="Material" /> <field name="Rating of pipe" /> <field name="Upstream Invert" /> <field name="Downstream Invert" /> <field name="As-built #" /> <field name="As-built link" popuponly="true" /> <field name="Status" /> <field name="Owned and maintained by" /> <field name="Comments" /> </fields> <links> <link includeinresults="false" field="As-built link" alias="Copy As-built" tooltip="Copy As-built"> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix>assets/images/dwgIcon.png</iconsuffix> </link> </links> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> <layer> <name>Force Main</name> <id>32</id> <url>http://server/svr/rest/services/UtilityLayers/MapServer</url> <fields all="false"> <field name="Size" /> <field name="Material" /> <field name="Rating of pipe" /> <field name="As-built #" /> <field name="As-built link" popuponly="true" /> <field name="Status" /> <field name="Owned and maintained by" /> <field name="Comments" /> </fields> <links> <link includeinresults="false" field="As-built link" alias="Copy As-built" tooltip="Copy As-built"> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix>assets/images/dwgIcon.png</iconsuffix> </link> </links> <zoomscale>15000</zoomscale> <forcescale>true</forcescale> </layer> <!-- End of Sewer Layers --> </layers> <symbols> <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid"> <outline color="0x448ccb" alpha="0.8" width="2" /> </simplefillsymbol> <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0xffffff" alpha="0.8" width="1" /> </simplemarkersymbol> <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0x448ccb" alpha="0.8" width="2" /> </symbols> </configuration>
if(identifyArrayCollection.length == 0 && numServicesIdent <= 0){ showMessage(noResultsFoundLbl, false); timedClose2(); }else if(identifyArrayCollection.length > 0 && numServicesIdent <= 0){ showMessage(resultsFoundLbl + " " + identifyArrayCollection.length, false); timedClose2(); }else{ disableTimer2(null); showMessage(loadingLabel + " " + layersRemaning + " " + numServicesIdent, true); }
Daniel, Can you give me some details on this? Are you selecting a particular layer from the drop down or just using the All Layers? are any of the layer that you have configured to identify a type="feature" in the main config.xml? You should only get that message when the returned results from the identify task is empty and there are no other results in the identify list.
<basemaps> <layer label="Base Layers" alpha="1" type="dynamic" visible="true" url="http://server/svr/rest/services/BaseLayers/MapServer" /> <layer label="2011 Aerial" type="dynamic" visible="false" url="http://server/svr/rest/services/AerialHybrid_2011/MapServer" /> <layer label="2009 Aerial" type="dynamic" visible="false" url="http://server/svr/rest/services/AerialHybrid_2009/MapServer" /> </basemaps> <operationallayers> <layer label="'11 Aerial" type="dynamic" visible="false" url="http://server/svr/rest/services/AerialLayer_2011/MapServer" /> <layer label="'09 Aerial" type="dynamic" visible="false" url="http://server/svr/rest/services/AerialLayer_2009/MapServer" /> <layer label="Cost Sharing" alpha="1" type="dynamic" visible="false" url="http://server/svr/rest/services/CostSharingLayers/MapServer" /> <layer label="Utility Layers and Streets" alpha="1" type="dynamic" visible="true" url="http://server/svr/rest/services/UtilityLayers/MapServer" /> <layer label="Routes" alpha="1" type="dynamic" visible="false" url="http://server/svr/rest/services/Routes/MapServer" /> <layer label="Notifications" alpha=".5" type="dynamic" visible="false" url="http://server/svr/rest/services/Notifications/MapServer/" /> </operationallayers>
Daniel, When you tried just two layer... Are both of them visible in the map?
Daniel, I will look into reproducing this.
Daniel, Give version 3.4.1 a try.
Daniel, I am not sure I can fix your issue with the widget without access to your specific data. Not being able to see the http traffic that the service is returning and whether the map service request is failing or the widget is failing to process properly, has me in the dark. I took a stab at a potential issue tracking the logic in my code with the 3.4.1 release, but as you said you are getting the same result...
Daniel, Ahh... That is why I did not see it in my testing. You are running into that issue because one of the map services is running on an older ArcGIS Server that has a bug that I have a workaround for. Thanks for the info.As far as comparing the eSearch and the Identify widget, that is like apples and oranges... The eSearch uses athe Query base task and only has to worry about on map service and the Identify uses the Identify base task and has to go to the server for each map service in the map.
Daniel:Did you recreate the mxds that are the source of your services from scratch? I ask because I have found that services still find references to old servers even if no layers are pointing to that data source anymore (I was getting locking issues with file geodatabases that were not being used). I'm not sure if this is why it is referencing a retired server, but I would think it is a possibility.
Unfortunately, that is what I found to be the case in my enterprise environment. I first just resourced the exising mxds from 1 source to another so the old source was not even being used, but locks were still being placed on the old source so I knew there were still references to the old source.I tried using MxdDoctor and SaveAs to get rid of the old source, but these workflows were never 100% effective. Recreating the mxd was the only 100% way of getting rid of references to the old data source.
