Several people are using the same webmap collecting data offline and when we go to sync that data once we are back in wifi some people are getting this error: "An error occurred while synchronizing edits. Unable to synchronize replica Exporting data changes failed"
Help please!
Hi Zach,
Thanks for the links.
I downloaded the data from the ipad, its rather big, 8mb. Including 5 folders each with a separate .gdb
I tired to use the ‘copy runtime geodatabase to file geodatabase” but I keep getting and error:
Any suggestions?
Thanks again
Katie
Hey Katie,
Thank you for the information! For a more immediate workflow to obtain the edits you can extract the runtime geodatabase directly from the devices and append the edits to the hosted feature layer in ArcGIS Online.
Please use these links for this workflow:
How To: Access offline edits from Collector for ArcGIS directly from an Android or iOS device
Manage hosted feature layers—ArcGIS Online Help | Documentation
Thank you,
Zach
I did try the push only, it did not help the sync. The process works about half way and stops with the error message.
Get Outlook for Android<https://aka.ms/ghei36>
Hello Zach,
We are using a webmap hosted on ArcOnline.
We are using ISO, and ArCollector classic.
Thank you!
Hi Katie,
To obtain a better picture of our workflow and behavior encountered I have a couple of additional questions.
Is the data hosted in ArcGIS Online or is the data coming from an ArcGIS Enterprise deployment? If the data is coming from an ArcGIS Enterprise deployment is the data registered with an Enterprise geodatabase?
Are we using Collector on IOS, Android, or Windows? If we are using IOS what version of Collector are we using Collector for ArcGIS 19.1.0 or Collector for ArcGIS Classic 19.0.2?
If we are using Collector for ArcGIS Windows, Android, or IOS Classic if we change our Synchronization settings to "Push Only" are we able to successfully sync the data?
