I have created simple service on my server and I'm trying to display it on a android device. However when I run the code all I get is a gray screen. The java code: import android.app.Activity; import android.os.Bundle; import com.esri.android.map.MapView; import com.esri.android.map.ags.ArcGISDynamicMapServiceLayer; public class MyPath_v02Activity extends Activity { MapView mMapView = null; private ArcGISDynamicMapServiceLayer dynamicLayer; /** Called when the activity is first created. */ @Override public void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.main); mMapView = (MapView)findViewById(R.id.map); dynamicLayer = new ArcGISDynamicMapServiceLayer("http://anc-arcsrv-01.ua.ad.alaska.edu/arcgis/services/myPath_v8/MapServer/MobileServer"); mMapView.addLayer(dynamicLayer); } @Override protected void onDestroy() { super.onDestroy(); } @Override protected void onPause() { super.onPause(); mMapView.pause(); } @Override protected void onResume() { super.onResume(); mMapView.unpause(); } }and the xml code in "main":<?xml version="1.0" encoding="utf-8"?> <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" xmlns:tools="http://schemas.android.com/tools" android:orientation="vertical" android:layout_width="fill_parent" android:layout_height="fill_parent" tools:context=".MyPath_v02Activity" > <com.esri.android.map.MapView android:id="@+id/map" android:layout_width="fill_parent" android:layout_height="fill_parent" initExtent = " -16713385.63038, 8560546.73163, -16546828.73922, 8746032.94837"> </com.esri.android.map.MapView> </LinearLayout>
I made the assumption that the args for initExtent are x min, y min, x max, and y max and I got the values from REST services dir.I there some thing simple that I'm doing wrong. Thnaks for any help.
