Dojo has a lot of built in animations such as fade out. dojo.fadeOut({ node:"Your Element", duration:700, onEnd: function(){ dojo.style("Your Element", "display", "none"); } }).play();Some examples can be found here http://dojotoolkit.org/reference-guide/dojo/fadeOut.html
// serialize the extent to JSON, create a new extent to later pass to the map var featExt = new esri.geometry.Extent(ext.toJson()); // listen to onExtentChange and then show a // graphic for the selected feature's extent this.extHandle = dojo.connect(this.map, 'onExtentChange', this, function() { var outline = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0, 173, 230, 1]), 3), symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, outline, new dojo.Color([0, 0, 128, 0])), extGraphic = new esri.Graphic(featExt, symbol); this.map.graphics.add(extGraphic); // fade out the graphic and remove it var fo = dojo.fadeOut({ 'node': extGraphic.getDojoShape().getNode(), 'duration': 1500, }); // remove the graphic and clean up the event listeners // after the animation plays this.foHandle = dojo.connect(fo, 'onEnd', this, function() { this.map.graphics.remove(extGraphic); dojo.disconnect(this.extHandle); dojo.disconnect(this.foHandle); }); fo.play(); }); // set the new extent this.map.setExtent(featExt, true);
