Thanks for the reply again. I went over the entire process again, but can't really tell what went wrong. Would it be possible for you to take a look at the files that I'm working with, if that's not too much of work for you?
Yes, that solved the problem. But after running the spacial join, I don't see the information about the polygons in the attribute table for the join output. What could have gone wrong there?
"The event table has no OID field or no unique value field, selections are not possible". I also tried to "join data", but a similar message occurs ("Source table must have an ObjectID column to perform a Join By Location")Again, thank you in advance for the help!
You can then add your spreadsheet table as an xy event layer. After that, you can save that layer as point feature class.
Hi, I am a student conducting a research on North Korean economic development. I think this must be a very basic question but could you help me with converting the GIS map into an excel spreadsheet?So I downloaded the administrative districts of the country (which I got from http://diva-gis.org/datadown) and imported that data to ArcMap 10.1. The map contains polygons each representing certain district, and what I'm trying to do is make an excel spreadsheet in which each cell represents a certain point of the map (based on latitude and longitude) and shows 1 if that point is included in that district or 0 if not.If my question is not so clear, I can elaborate more on that. Thank you so much in advance!
