class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" self.params[0].filter.list = ['val1', 'val2', 'val3', 'val4'] return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parmater has been changed.""" if not self.params[0].altered: self.params[0].value = r"'val1';'val2';'val3'" return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
