I use ArcGIS JavaScript API 4.1 ( it was in ArcGIS JavaScript API 3.1 )and could not update this code in this version. Any ideas how to do it? Data responses, but autocomplete does not work:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>Sample Code</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="//code.jquery.com/ui/1.11.1/themes/smoothness/jquery-ui.css">
</style>
<script>
require(["esri/Map","esri/views/MapView", "esri/tasks/QueryTask","esri/tasks/support/Query","dojo/domReady!"],
function (Map, MapView, QueryTask, Query) {
var map;
var map = new Map({
basemap: "topo-vector"
var view = new MapView({
container: "viewDiv",
map: map,
extent: { // Extent Chemi rukistvis()
xmin: 5278000,
ymin: 5147000,
xmax: 4377000,
ymax: 5247784,
spatialReference: 102100
$(function () {
var array = []
queryTask = new QueryTask("localhost:6080/arcgis/rest/services/Melioracia_Geo_201801251705/MapServer/3");
query = new Query();
query.returnGeometry = false;
query.outFields = ["სარწყავი_სისტემა"];
query.where = "OBJECTID > 0";
queryTask.execute(query, showResults);
function showResults(results) {
// Collect the results
var resultItems = [];
var resultCount = results.features.length;
for (var i = 0; i < resultCount; i++) {
var featureAttributes = results.features[i].attributes;
for (var attr in featureAttributes) {
// Convert the attribute to a string. Null Values create an extra comma which stops the widget from functioning.
tags = String(featureAttributes[attr]);
// push the attributes tothe blank array
resultItems.push(tags);
// Sort the array
sorted = resultItems.sort()
// Remove Duplicates
var uniqueNames = [];
$.each(sorted, function (i, el) {
if ($.inArray(el, uniqueNames) === -1) uniqueNames.push(el);
// Set the varrible array
array = uniqueNames
// This is your AutoComplete Widget
var availableTags = array;
// Reference the div id which you want the autocomplete list to appear (in this case tag)
$("#tags").autocomplete({
// set the source as the availble tags above
source: availableTags
</script>
</head>
<body>
<div class="ui-widget">
<label for="tags">Tags: </label>
<input id="tags">
</div>
<div id="map"></div>
<div id="viewDiv"></div>
</body>
</html>
