Hello All
I downloaded a ESRI ajavascript template from github... and I want to add a arcgis server web service instead of the webmap id
when I see the index.html file i see the code as : I need to skip the webmap and use my REST web service instead..
var defaults = {
//The ID for the map from ArcGIS.com
webmap: "f5b13dbed07c46cdb783cf361833aa6b", I WANT TO ADD my Service http://111.11.1.1/arcgis/services/test/mapserver
//Modify this to point to your sharing service URL if you are using the portal
sharingurl: "http://www.arcgis.com",//for example: "http://www.arcgis.com",
//The id for the web mapping application item that contains configuration info - in most
////When editing you need to specify a proxyurl (see below) if the service is on a different domain
//Specify a proxy url if you will be editing, using the elevation profile or have secure services or web maps that are not shared with everyone.
proxyurl: "",
//cases this will be null.
appid: "",
//set to true to display the title
displaytitle: true,
//Enter a title, if
Can some one help me out in this
