Is there any way to change the mouse cursor on the map after activating the SketchViewModel in the latest version of the javascript API? I tried doing it with css with no luck.
viewDiv.style.cursor = "default";
Here is a bit of a sledgehammer way to force the issue (in typescript, but it should be even simpler in plain javascript):
@Ben Elan - ESRI support says this is not possible without downloading the API javascript and hacking it, so I have given up on doing this.
In vanilla JavaScript it would be
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>cursor <SPAN class="operator token">=</SPAN> <SPAN class="string token">"default"</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
If that doesn't work you could try using jQuery
<SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#viewDiv'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">css</SPAN><SPAN class="punctuation token">(</SPAN> <SPAN class="string token">'cursor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'default'</SPAN> <SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
jQuery CDN:
<SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://code.jquery.com/jquery-3.4.1.min.js<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">integrity</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>sha256-CSXorXvZcTkaix6Yvo6HppcZGetbYMGWSFlBw8HfCJo<SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">crossorigin</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>anonymous<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
