The documentation describes the extent which is displayed in the Overview Map as below:"Displays the map extent zoomed out three times the main map display (until the maximum extent is reached)."http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Overview_Map_widget/01m30000003r000000/I don't have a true base map in my application. The service used by the Overview map has a upper scale threshold of 1:100,000. However once my map goes beyond a scale of 1:8100 I no longer get anything in my overview. I got a value of 8100 by making my map perfectly square. On a more rectangular map it disappears at around 1:6000.The documentation would suggest that the overview should be showing the map at 1:24300 (8100 x 3) in which case the I should still see the map service. If the documentation meant 3 zoom levels then it would still be visible, showing 1:64800 (8100 x 2 x 2 x 2).Am I misreading the documentation? Is the documentation just wrong? Or is something odd with my application/map service?
private function updateOverviewExtentFromMap():void { overviewMap.extent = map.extent.expand(3); overviewGraphic.geometry = map.visibleArea; //hide overview box if larger than overview map overviewGraphic.visible = overviewMap.extent.contains(overviewGraphic.geometry); }
