Hi I know that there is a lot of discussion about this error. But when i tried to apply the sollution presented, i still get the same error.
Here is my problem definition.
I have
-2.6.18-371.6.1.el5 GNU/Linux 64 bit
-Oracle 11.2.0
-Arcgis 10.2
installed.
I create a geodatabase using arccatolog software, and after that i import some tables to this geodatabase. However when i try to use some functions of this geodatabase such as st_astext i get "unable to open RPC connection to external procedure agent" error. The complete error list is given below.
ORA-28575: unable to open RPC connection to external procedure agent
ORA-06512: at "SDE.ST_GEOMETRY_SHAPELIB_PKG", line 67
ORA-06512: at "SDE.ST_GEOMETRY_OPERATORS", line 118
28575. 00000 - "unable to open RPC connection to external procedure agent"
I checked for this error and found out that oracle requires some configurations for calling functions from extarnal libraries.In this case the library is libst_shapelib.so. I tried to make some configrurations in accordance to oracle documantation. The content of listener.ora, tnsnames.ora and extrproc.ora is given below.
listener.ora
ID_LIST_LISTENER =
(SID_LIST =
(SID_DESC =
(SID_NAME = PLSExtProc)
(ORACLE_HOME = /u01/app/oracle11/product/11.2.0/dbhome_1)
(PROGRAM = extproc)
(SID_DESC =
(GLOBAL_DBNAME = PGEO01)
(SID_NAME = PGEO01)
(SID_DESC =
(SID_NAME = PLSExtProcSDE)
(PROGRAM = extproc)
(ENVS="EXTPROC_DLLS=/geocode/arcgis/server/lib/libst_shapelib.so")
(SID_DESC =
(SID_NAME = xyz)
(PROGRAM = dg4odbc)
(ENVS="LD_LIBRARY_PATH=/u01/app/oracle11/product/11.2.0/dbhome_1/bin")
LISTENER =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = xyz.xyz.xyz.xyz)(PORT = 1525))
(ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROCSDE1528))
#----ADDED BY TNSLSNR 19-FEB-2014 16:45:13---
PASSWORDS_LISTENER = xyz
tnsnames.ora
PGEO01=
(DESCRIPTION=
(ADDRESS=
(PROTOCOL=TCP)
(HOST=xyz.xyz.xyz.xyz)
(PORT=1525)
(CONNECT_DATA=
(SERVER = DEDICATED)
(SERVICE_NAME=PGEO01)
EXTPROC_CONNECTION_DATA =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = IPC)(Key = EXTPROCSDE1528))
(CONNECT_DATA =
(SID =PLSExtProcSDE)
(PRESENTATION = RO)
PGSQL =
(DESCRIPTION=
(ADDRESS=(PROTOCOL=tcp)(HOST=xyz.xyz.xyz.xyz)(PORT=1525))
(CONNECT_DATA = (SID = xyz))
(HS = OK)
extproc.ora
-I tried all options below:
SET EXTPROC_DLLS=
SET EXTPROC_DLLS=ANY
SET EXTPROC_DLLS=ONLY:/dddd/arcgis/server/DatabaseSupport/Oracle/Linux64/lib
After changing this files. I got the same error. As error indicates that there are 3 possibilities for this error.
- Something wrong in tnsnames or listener. ora files
-Incorrect keys or not matching
-Network issues
-Or the library is corrupted.
I still think that i dis some mistake in the tnsnames and listener . ora file configuration. But i do not know where is the mistake can you help me .
one final note:
my lsnrctl status output is:
Listening Endpoints Summary...
(DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(KEY=LISTENER)))
(DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=xyz.xyz.xyz.xyz)(PORT=1525)))
Services Summary...
Service "+ASM" has 1 instance(s).
Instance "+ASM", status READY, has 1 handler(s) for this service...
Service "PGEO01" has 1 instance(s).
Instance "PGEO01", status READY, has 1 handler(s) for this service...
Service "PGEO01XDB" has 1 instance(s).
The command completed successfully
Thank You for your Time
