Hey Sol,
I took a closer look at this and have a cookie'less solution for you.
The int's were working fine for me but I can see how it gets unwieldy with large or dynamic numbers.
Imports ESRI.ArcGIS.Desktop.AddIns Imports ESRI.ArcGIS.Framework Public Class Cbt Inherits ESRI.ArcGIS.Desktop.AddIns.ComboBox Public Sub New() 'Populate the combo box with the years e.g. 1999-2014 For i As Integer = 2014 To 1999 Step -1 Me.Add(i.ToString()) Next 'Set the default value for the combo Dim globalDefault As String = "2000" SelectYear(globalDefault) 'Get the def query year value from the layer. Assume a value. Dim defQueryYear As String = "2003" 'If defquery year is in the combo box list then use that otherwise the default has been set above SelectYear(defQueryYear) End Sub Protected Overrides Sub OnSelChange(cookie As Integer) 'The user has selected a year Dim newYear = Me.GetItem(cookie).Caption End Sub Public Sub SelectYear(year As String) 'Select the item in the combo from the string For Each item As ComboBox.Item In Me.items If item.Caption = year Then Me.Select(item.Cookie) Exit For End If Next End Sub
In this example I populate the combo box with the range. You'll get the max value from your sql table.
I then set the combo box to a default value of 2000, an example of your global default.
You would then select a value based on your def query if applicable.
If the user selects a year, you can pick it up from the newYear variable in OnSelChange.
Hope this helps
Sean.
I had a hard time with the add-in combox box also.
Programmatically selecting the item was easy enough but it wouldn't show the value of that item in the textbox unless I explicitly set the value property.
Here's some c# code from 10.0 that creates a combo box containing the three z capture types for the editor. The actual z capture type is then set when the mxd is opened. This behavior may have changed in later versions but I haven't tried it recently.
public ZCaptureModeCombo() { _cz = this.Add("CurrentZ"); _iz = this.Add("InterpolateZ"); _sz = this.Add("SurfaceZ"); _editor = ArcMap.Editor; _editorZ = _editor as IEditorZ; _docEvents = ArcMap.Document as IDocumentEvents_Event; _docEvents.OpenDocument += new IDocumentEvents_OpenDocumentEventHandler(_docEvents_OpenDocument); _docEvents.NewDocument += new IDocumentEvents_NewDocumentEventHandler(_docEvents_NewDocument); } void switchCaptureType(esriZCaptureType ezt) { switch (ezt) { case esriZCaptureType.esriCaptureCurrentZ: this.Value = "CurrentZ"; this.Select(_cz); break; case esriZCaptureType.esriCaptureInterpolateZ: this.Value = "InterpolateZ"; this.Select(_iz); break; case esriZCaptureType.esriCaptureSurfaceZ: this.Value = "SurfaceZ"; this.Select(_sz); break; default: this.Value = "CurrentZ"; this.Select(_cz); break; } } void _docEvents_NewDocument() { switchCaptureType(_editorZ.ZCaptureType); }
Public Sub New() Dim mymap As IMap = mxDoc.FocusMap Try If mymap.LayerCount > 0 Then Me.Enabled = True For i As Integer = 0 To mymap.LayerCount - 1 Me.Add(mymap.Layer(i).Name) Next 'Set the default selected value in the comboBox Me.Select(0) 'This line here won't work. I wish we could have the selectedIndex instance as on a normal window's form Else Me.Enabled = False End If Catch ex As Exception MessageBox.Show(ex.Message) End Try End Sub
You can set the combobox's text property to "Select storm". Once something is selected, that text will not show up again.
