We are using Javascript API 3.21 and trying to set the renderer for a StreamLayer. Debugging through the chrome dev tools we can see that it's applying the renderer correctly to the layer but we see all the default blue circles disappear and none ever show. But we can see the features actually streaming in over the network tab in the websocket connection frames. Can someone verify this UniqueValueRenderer is valid on their stream layer?
<SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"uniqueValue"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"attributeField"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"groupid"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"visualVariables"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"rotationInfo"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"field"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"heading"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"rotationType"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"geographic"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"defaultSymbol"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"outline"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"width"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSLS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"style"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSLSNull"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSFS"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"style"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSFSNull"</SPAN>
<SPAN class="string token">"uniqueValueInfos"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"value"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ASB"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"symbol"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"style"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSLSSolid"</SPAN>
<SPAN class="string token">"style"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriSFSSolid"</SPAN>
<SPAN class="string token">"value"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"WG"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
