All,
When zooming in on the US topographic map service, the layer turns off. Is there any way to remove this minimum extent? Can Esri republish this service without a minimum extent applied?
Here is the path to the service:
http://services.arcgisonline.com/arcgis/rest/services/USA_Topo_Maps/MapServer
Thanks!
The topographic map service turns off between Zoom level 15 and 16. It appears the new max zoom level is 23.
You can view a sample here www.centerlinemapping.com/topographic.htm
Wondering if Esri could possibly republish the topographic web service without the minimum extent allowing us to view the topo maps beyond Zoom level 15?
I believe this to be a result of your application zooming in past zoom level 19. Recently, Esri updated our zoom levels to exceed zoom level 19. This will be more meaningful in future releases of data services from Esri.
Hope this helps!
