Thanks for the reply. Yes - it requires at least Standard licensing. If you work a lot with rasters it might be worth it just because of that. Hope you have success with the procedures described by Dan and Abdullah
Thanks for the answer Gunter. My only issue is that I have no access to the right licence to create a Mosaic Dataset under Data Management. Therefore I will follow Abdullah and Dan's advice.
Really appreciate though
The MosaicDataset Fan is back: You should create a MosaicDataset and load both. Where one has a higher resolution than the other - it will be used - thats the simple version. There is a lot you can set as properties, too. No need to calculate them into a new dataset, if you dont want to. Though thats an option, no doubt.
Con with IsNull generically Con(IsNull(small), big, small)
If they overlap and same spatial reference, use Mosaic To New Raster—Help | ArcGIS for Desktop tool and make the mosaic operator refer to Ras2 in your input raster sort, as the following picture.
