Hi
Any one can please guide me or give me a sample to understand how can create Polyline feature layer with web service(JSON).
I have created Point feature layer with web service but i am stuck to create line feature that how can i loop path/segments.
Following is the code of my Polyline feature layer......robert scheitlin
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN>
content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>JSON<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#viewDiv <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link
rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN>
href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.12/esri/themes/light/main.css"</SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.12/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Polyline"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/FeatureLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/Search"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/Legend"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/projection"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/SpatialReference"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> esriRequest<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN>Polyline<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN>Search<SPAN class="punctuation token">,</SPAN> Legend<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">,</SPAN>QueryTask<SPAN class="punctuation token">,</SPAN> projection<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
projection<SPAN class="punctuation token">.</SPAN><SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> url <SPAN class="operator token">=</SPAN><SPAN class="string token">"http://172.16.6.28:2019/geojson"</SPAN>
<SPAN class="keyword token">let</SPAN> myData <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">let</SPAN> fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"oid"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Capacity"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Capacity"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"string"</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"long"</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> pTemplate <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"{title}"</SPAN><SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"fields"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Capacity"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Capacity"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">,</SPAN>
fieldName<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN>
label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">/* var rendererCheck = {
type: "unique-value", // autocasts as new UniqueValueRenderer()
field: "POP",
defaultSymbol: {
type: "simple-marker",
color: "black",
outline: { // autocasts as new SimpleLineSymbol()
width: 0.5,
color: "white"
}, // autocasts as new SimpleFillSymbol()
uniqueValueInfos: [{
// All features with value of "North" will be blue
value: 21001,
symbol: {
type: "simple-marker", // autocasts as new SimpleFillSymbol()
color: "blue",
width: 0.5,
color: "white"
// All features with value of "East" will be green
value: 21003,
symbol: {
color: "green",
width: 0.5,
color: "white"
// All features with value of "South" will be red
value: 21004,
symbol: {
color: "red",
width: 0.5,
color: "white"
// All features with value of "West" will be yellow
value: 21005,
symbol: {
color: "yellow",
width: 0.5,
color: "black"
value: 21006,
symbol: {
color: "#ba0af3",
width: 0.5,
color: "white"
*/</SPAN>
<SPAN class="keyword token">let</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"satellite"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">67.068037</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">24.872328</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">12</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map
<SPAN class="keyword token">let</SPAN> options <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
query<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
f<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN>
responseType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"json"</SPAN>
<SPAN class="keyword token">let</SPAN> fetchData <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">,</SPAN> options<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>response <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> response<SPAN class="punctuation token">.</SPAN>data<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> webservice <SPAN class="operator token">=</SPAN> res <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
res<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">,</SPAN> i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> resultPnts <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>Shape<SPAN class="punctuation token">.</SPAN>points<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>point<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polyline</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
paths<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN>point<SPAN class="punctuation token">.</SPAN>x<SPAN class="punctuation token">,</SPAN> point<SPAN class="punctuation token">.</SPAN>y<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
hasZ<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
hasM<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
spatialReference <SPAN class="punctuation token">:</SPAN> result<SPAN class="punctuation token">.</SPAN>Shape<SPAN class="punctuation token">.</SPAN>srid
<SPAN class="keyword token">let</SPAN> atts <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">:</SPAN> i<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Name"</SPAN><SPAN class="punctuation token">:</SPAN> result<SPAN class="punctuation token">.</SPAN>Capacity<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">:</SPAN> result<SPAN class="punctuation token">.</SPAN>POP<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Placement"</SPAN><SPAN class="punctuation token">:</SPAN> result<SPAN class="punctuation token">.</SPAN>Placement<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Comment"</SPAN><SPAN class="punctuation token">:</SPAN> result<SPAN class="punctuation token">.</SPAN>Comment
<SPAN class="keyword token">let</SPAN> graArr <SPAN class="operator token">=</SPAN> resultPnts<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>pnt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> projectedPoint <SPAN class="operator token">=</SPAN> projection<SPAN class="punctuation token">.</SPAN><SPAN class="token function">project</SPAN><SPAN class="punctuation token">(</SPAN>pnt<SPAN class="punctuation token">,</SPAN>view<SPAN class="punctuation token">.</SPAN>spatialReference<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> markerSymbol <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-line"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// autocasts as SimpleLineSymbol()</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">226</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">119</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">40</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN>
<SPAN class="keyword token">let</SPAN> g <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN>projectedPoint<SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> markerSymbol<SPAN class="punctuation token">,</SPAN>
attributes<SPAN class="punctuation token">:</SPAN> atts
myData<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>g<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> graArr
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>myData<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometryType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"polyline"</SPAN><SPAN class="punctuation token">,</SPAN>
source<SPAN class="punctuation token">:</SPAN> myData<SPAN class="punctuation token">,</SPAN>
fields<SPAN class="punctuation token">:</SPAN> fields<SPAN class="punctuation token">,</SPAN>
objectIdField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ObjectID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//renderer: rendererCheck,</SPAN>
popupTemplate<SPAN class="punctuation token">:</SPAN> pTemplate<SPAN class="punctuation token">,</SPAN>
<SPAN class="comment token">//definitionExpression: "CATEGORY= '2 Wheeler'"</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">/* var searchWidget = new Search({
view: view,
sources:[
layer: layer,
searchFields: ["ID"],
displayField: "ID",
exactMatch: false,
outFields: ["*"],
placeholder: "2100103",
scale: 10,
maxResults: 6,
maxSuggestions: 6,
minSuggestCharacters: 0,
resultSymbol: {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
color: [239, 25, 25],
width: 30,
height: 30,
xoffset: 0,
yoffset: 0
});*/</SPAN>
<SPAN class="keyword token">var</SPAN> legend <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Legend</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
layerInfos<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">{</SPAN>
layer<SPAN class="punctuation token">:</SPAN> layer<SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Legend"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">]</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>legend<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>searchWidget<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
position<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">,</SPAN>
index<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">fetchData</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>webservice<SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
