<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Measure Areas"> <!-- This sample shows how to use the DrawTool and GeometryService to: - simplify ("clean") the drawn polygon - measure the area of the polygon - create a properly placed label for the polygon Workflow for this sample: 1. Click on map to draw an area 2. Double-click to end the drawing -> Calls onDrawEnd (as set up in DrawTool): Sends polygon to geometry service for clean-up/simplication (in case lines cross etc) -> When simplify has completed, simplifyCompleteHandler(event) is called (as setup in GeometryService task): Adds cleaned up graphic to the graphics layer. Sends cleaned up graphic to geometry service to be "measured". -> When areasAndLengths has completed successfully, areasAndLengths_resultHandler is called. Get the area. Sends request for best placement of the label -> When labelPoints has completed successfully, labelPoints_resultHandler will: Display a label with the area. --> <s:layout> <s:VerticalLayout horizontalAlign="center" paddingTop="5"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.DrawEvent; import com.esri.ags.events.GeometryServiceEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Geometry; import com.esri.ags.symbols.TextSymbol; import com.esri.ags.tasks.supportClasses.AreasAndLengthsParameters; import com.esri.ags.tasks.supportClasses.AreasAndLengthsResult; import mx.controls.Alert; import mx.rpc.AsyncResponder; import mx.rpc.Fault; private function activateTool():void { drawTool.activate(DrawTool.POLYGON); act.enabled = false; deact.enabled = true; } private function deactivateTool():void { drawTool.deactivate(); deact.enabled = false; act.enabled = true; } private function onDrawEnd(event:DrawEvent):void { // simplify the drawn polygon // Note: As of version 2.0, GeometryService input is geometries (instead of graphics). geometryService.simplify([ event.graphic.geometry ]); } private function simplifyCompleteHandler(event:GeometryServiceEvent):void { // Note: GeometryService returns geometries instead of graphics as of Flex API 2.0 if (event.result) { var polygon:Geometry = (event.result as Array)[0]; // we only draw one area at a time var newGraphic:Graphic = new Graphic(polygon); newGraphic.autoMoveToTop = false; myGraphicsLayer.add(newGraphic); // project to 54034 (World_Cylindrical_Equal_Area) geometryService.project([ polygon ], new SpatialReference(54034), new AsyncResponder(project_resultHandler, project_faultHandler, polygon)); } } private function project_resultHandler(result:Object, token:Object = null):void { if (result) { var polygon:Geometry = (result as Array)[0]; var areasAndLengthsParameters:AreasAndLengthsParameters = new AreasAndLengthsParameters(); areasAndLengthsParameters.areaUnit = GeometryService.UNIT_SQUARE_KILOMETERS; areasAndLengthsParameters.polygons = [ polygon ]; geometryService.areasAndLengths(areasAndLengthsParameters, new AsyncResponder(areasAndLengths_resultHandler, areasAndLengths_faultHandler, token)); } } private function project_faultHandler(fault:Fault, token:Object = null):void { Alert.show(fault.faultString + "\n\n" + fault.faultDetail, "project Fault " + fault.faultCode); } private function areasAndLengths_resultHandler(result:AreasAndLengthsResult, token:Object = null):void { const area:String = myNumberFormatter.format(result.areas[0]); geometryService.labelPoints([ token ], new AsyncResponder(labelPoints_resultHandler, labelPoints_faultHandler, area + " km2.")); } private function areasAndLengths_faultHandler(fault:Fault, token:Object = null):void { Alert.show(fault.faultString + "\n\n" + fault.faultDetail, "areasAndLengths Fault " + fault.faultCode); } private function labelPoints_resultHandler(result:Object, token:Object = null):void { for each (var geom:Geometry in result) { var g:Graphic = new Graphic(); g.geometry = geom; var tf:TextFormat = new TextFormat(null, 16, 0x00FF00); g.symbol = new TextSymbol(String(token), null, 0xFFFFFF, true, 0xFFFFFF, true, 0xFF0000, "middle", 0, 0, 0, tf); myGraphicsLayer.add(g); } } private function labelPoints_faultHandler(fault:Fault, token:Object = null):void { Alert.show(fault.faultString + "\n\n" + fault.faultDetail, "labelPoints Fault " + fault.faultCode); } ]]> </fx:Script> <fx:Declarations> <esri:DrawTool id="drawTool" drawEnd="onDrawEnd(event)" fillSymbol="{mySFS}" map="{myMap}"/> <esri:GeometryService id="geometryService" showBusyCursor="true" simplifyComplete="simplifyCompleteHandler(event)" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/> <esri:SimpleFillSymbol id="mySFS" color="0xAA0000"> <esri:SimpleLineSymbol width="2" color="0xAA0000"/> </esri:SimpleFillSymbol> <mx:NumberFormatter id="myNumberFormatter" precision="2" useThousandsSeparator="true"/> </fx:Declarations> <s:Label color="0xAA0000" fontSize="14" text="Draw an area with at least three nodes."/> <s:HGroup> <s:Button id="deact" click="deactivateTool()" label="Stop measuring"/> <s:Button id="act" click="activateTool()" enabled="false" label="Start measuring"/> </s:HGroup> <esri:Map id="myMap" extent="{new Extent(-13658000, 5703000, -13655000, 5705000, new SpatialReference(102100))}" load="drawTool.activate(DrawTool.POLYGON)"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" symbol="{mySFS}"/> </esri:Map> </s:Application>
