invalid link error
Jamal when I click on the link in your initial thread, that is error message I got. Usually you have images in your threads but not this time.
Dan,The link is working for me for some reason...That is how I knew his syntax was correct.Eric
First, you have to tell me what you mean by "not working". Is there an error? Is the output wrong? Have you tried running the Plus tool instead? Eric
try sending your output to a folder rather than a geodatabasealso ensure that both files have the same projection
Jamal,Please send a screenshot of 'B' layer properties so I can see the extent values. Please do the same for Elevation. What happens if you add Elevation to a blank map, then add B to it? Does B overlay Elevation? If layer B has the same extent values as layer A that you uploaded to this forum, that would explain the issue. You can't add two rasters together if they don't line up with one another.Eric
