I am using a Personal Geodatabase and i am not able to make out how i can return more than one value as of now, in the query. request help to modify my existing query in such a way that it suits where_clause of SelectLayerbyAttributes. As a beginner in arcobjects I honestly do not know what Summary statistics is. Regards,Pavan
Unless you use a Personal Geodatabase (Access) or an SDE database like SQL Server or Oracle, GROUP BY can only return one value and cannot be correlated to any other fields in a table (I.e., the max is for every record in the entire table). A file geodatabase or shapefile do not support the subquery syntax you want to use. For those types of databases you must use the Summary Statistics tool and a join to do the selection based on the joined grouped summary values. A multi-field join would have to use the Make Query Table tool.Generally I breakdown and concatenate the multiple fields and use the Summary Statistics to do the selection or data transfer through a standard join.
A similar post was left unanswered http://forums.arcgis.com/threads/29621-Selection-QUERY-duplicits?highlight=GROUP+BY , I had tried to do a workaround as mentioned in the link by using WHERE .. IN ( Select .. GROUP BY .. HAVING ..) but the problem I need to perform GROUP BY on multiple fields and need to Select Longitude and Latitude in Subquery, hence i cannot use "WHERE Longitude, Latitude IN" as you can use only one field while using IN.Request any kind of help.Regards,Pavan
Hi,I am developing a stand alone C# Map control application using ArcGIS Engine 10.1. I am trying to select features in a point feature class using "SelectLayerByAttribute" class which requires me to use to use GROUP BY keyword.. The Query goes something like this..SELECT LONGITUDE, LATITUDE, COUNT(LONGITUDE) FROM LAYER123 GROUP BY LONGITUDE,LATITUDE HAVING COUNT(LONGITUDE) > 5;The idea is to select all the features that have been plotted more than 5 times for a given longitude and latitude. My problem here is that I am unable to execute the above query in SelectLayerByAttribute.where_clause, is there a way that i can execute GROUP BY statements to select features in a given layer. Also let me know if there is a workaround for this..Thanks and Regards,Santosh Pavan Kumar N
