In ArcGIS 10 I tried using the add surface information using a Point feature class (FC) and a terrain. The tool is supposed to add a field and add the elevation information, like the surface spot in 9.3.1 for Tin's and grids, but it did not do so. I tried converting the Terrain to a Tin but it failed due to to many points. Any suggestions?Thanks!
Hi Koen,New at 10 is that you can run most analytical operators that work with TINs directly against Terrains. 1 exception: �??Extrude between�??.Regards Gert3Dteam
