<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Attribute Inspector (edit)"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.FeatureLayerEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.symbols.SimpleFillSymbol; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.rpc.events.FaultEvent; private var mapClickPoint:MapPoint; protected function map_mapClickHandler(event:MapMouseEvent):void { // convert click to an extents var vPt:MapPoint = event.mapPoint; mapClickPoint = event.mapPoint; var vX:Number = vPt.x; var vY:Number = vPt.y; var vExtent:Extent = new Extent(vX - 100, vY - 100,vX + 100, vY + 100) var thisSelectionQuery:Query = new Query(); thisSelectionQuery.geometry = vExtent; myFeatureLayer.selectFeatures(thisSelectionQuery, FeatureLayer.SELECTION_NEW); } protected function attrInsp_faultHandler(event:FaultEvent):void { Alert.show(event.fault.message, "Fault"); } protected function myFeatureLayer_selectionCompleteHandler(event:FeatureLayerEvent):void { // only show infoWindow if a feature was found if (event.featureLayer.numGraphics > 0){ myMap.infoWindow.label = "Sign " + event.featureLayer.selectedFeatures[0].attributes.OBJECTID; myMap.infoWindow.show(mapClickPoint); }else{ Alert.show("Sorry found nothing here..."); } } ]]> </fx:Script> <fx:Declarations> <esri:Query id="queryMapClick"/> </fx:Declarations> <fx:Style> @namespace s "library://ns.adobe.com/flex/spark"; @namespace esri "http://www.esri.com/2008/ags"; esri|InfoWindow { background-color: #BDB76B; /* dark khaki */ border-color: #000000; border-thickness: 3; lower-left-radius: 20; lower-right-radius: 20; upper-left-radius: 20; upper-right-radius: 0; padding-bottom: 7; padding-left: 7; padding-right: 7; padding-top: 4; } esri|InfoWindowLabel { color: #FFFFFF; font-size: 15; padding-left: 120; } s|BorderContainer { background-color: #F0E68C; /* light khaki */ corner-radius: 15; content-background-color: #BDB76B; padding-bottom: 5; } </fx:Style> <s:layout> <s:VerticalLayout/> </s:layout> <esri:Map id="myMap" load="attrInsp.featureLayers = [myFeatureLayer]" mapClick="map_mapClickHandler(event)" openHandCursorVisible="false"> <!-- Extent for Woukesha Signs --> <esri:extent> <esri:Extent xmin="2468000" ymin="371000" xmax="2475000" ymax="376000"> <esri:SpatialReference wkid="32054"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer url="https://maps.ags.ruekert-mielke.com/AGS/rest/services/WaukeshaCity/WaukeshaSignsSampleSigns/MapServer"/> <esri:ArcGISDynamicMapServiceLayer url="https://maps.ags.ruekert-mielke.com/AGS/rest/services/WaukeshaCity/WaukeshaSignsSampleApp2/MapServer"/> <esri:FeatureLayer id="myFeatureLayer" mode="selection" outFields="[HouseNumber,StreetName]" selectionColor="0x000000" selectionComplete="myFeatureLayer_selectionCompleteHandler(event)" url="https://maps.ags.ruekert-mielke.com/AGS/rest/services/WaukeshaCity/WaukeshaSignsSampleSigns/MapServer/0"/> <esri:GraphicsLayer id="myGraphicsLayer"> <esri:Graphic> <esri:geometry> <esri:MapPoint x="2471315" y="374682" spatialReference="{new SpatialReference(32054)}"/> </esri:geometry> </esri:Graphic> </esri:GraphicsLayer> <esri:infoWindowContent> <s:BorderContainer> <esri:AttributeInspector id="attrInsp"/> </s:BorderContainer> </esri:infoWindowContent> </esri:Map> <s:Label text="The feature layer has {myFeatureLayer.selectedFeatures.length} selected feature(s)."/> </s:Application>
Cannot access a property or method of a null object reference.
try { var myObject:Object = new Object(); // myObject is not null myObject.myParameter = "Hello world!"; var message:String = myObject.myParameter; trace(message); } catch (error:Error) { trace(error.message.toString()); }
try { var myObject:Object = new Object(); // myObject is null var message:String = myObject.myParameter; trace(message); } catch (error:Error) { trace(error.message.toString()); }
<fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.FeatureLayerEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.layers.FeatureLayer; import com.esri.ags.symbols.SimpleFillSymbol; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.rpc.events.FaultEvent; protected function map_mapClickHandler(event:MapMouseEvent):void { // convert click to an extents var vPt:MapPoint = event.mapPoint; queryMapClick = event.mapPoint; var vX:Number = vPt.x; var vY:Number = vPt.y; var vExtent:Extent = new Extent(vX - 100, vY - 100,vX + 100, vY + 100) var thisSelectionQuery:Query = new Query(); thisSelectionQuery.geometry = vExtent; var myFeatureLayer:FeatureLayer = new FeatureLayer; } protected function attrInsp_faultHandler(event:FaultEvent):void { Alert.show(event.fault.message, "Fault"); } protected function myFeatureLayer_selectionCompleteHandler(event:FeatureLayerEvent):void { // only show infoWindow if a feature was found if (event.featureLayer.numGraphics > 0) { myMap.infoWindow.label = "Sign " + event.featureLayer.selectedFeatures[0].attributes.OBJECTID; //I am not sure what I should do with this myMap.infoWindow.show(queryMapClick.geometry as MapPoint); } else { Alert.show("Sorry found nothing here..."); } } ]]> </fx:Script>
1067: Implicit coercion of a value of type com.esri.ags.geometry:MapPoint to an unrelated type com.esri.ags.tasks.supportClasses:Query
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Attribute Inspector (edit)"> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.events.FeatureLayerEvent; import com.esri.ags.events.MapMouseEvent; import com.esri.ags.geometry.Extent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Polygon; import com.esri.ags.symbols.SimpleFillSymbol; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.rpc.events.FaultEvent; //public var queryMapClick1:MapPoint; protected function map_mapClickHandler(event:MapMouseEvent):void { // convert click to an extents var vPt:MapPoint = event.mapPoint; queryMapClick = event.mapPoint; var vX:Number = vPt.x; var vY:Number = vPt.y; var vExtent:Extent = new Extent(vX - 100, vY - 100,vX + 100, vY + 100) var thisSelectionQuery:Query = new Query(); thisSelectionQuery.geometry = vExtent; myFeatureLayer.selectFeatures(thisSelectionQuery, FeatureLayer.SELECTION_NEW); } protected function attrInsp_faultHandler(event:FaultEvent):void { Alert.show(event.fault.message, "Fault"); } protected function myFeatureLayer_selectionCompleteHandler(event:FeatureLayerEvent):void { // only show infoWindow if a feature was found if (event.featureLayer.numGraphics > 0) { myMap.infoWindow.label = "Sign " + event.featureLayer.selectedFeatures[0].attributes.OBJECTID; //I am not sure what I should do with this myMap.infoWindow.show(queryMapClick.geometry as MapPoint); } else { Alert.show("Sorry found nothing here..."); } } ]]> </fx:Script> <fx:Declarations> <esri:Query id="queryMapClick"/> </fx:Declarations> <fx:Style> @namespace s "library://ns.adobe.com/flex/spark"; @namespace esri "http://www.esri.com/2008/ags"; esri|InfoWindow { background-color: #BDB76B; /* dark khaki */ border-color: #000000; border-thickness: 3; lower-left-radius: 20; lower-right-radius: 20; upper-left-radius: 20; upper-right-radius: 0; padding-bottom: 7; padding-left: 7; padding-right: 7; padding-top: 4; } esri|InfoWindowLabel { color: #FFFFFF; font-size: 15; padding-left: 120; } s|BorderContainer { background-color: #F0E68C; /* light khaki */ corner-radius: 15; content-background-color: #BDB76B; padding-bottom: 5; } </fx:Style> <s:layout> <s:VerticalLayout/> </s:layout> <esri:Map id="myMap" load="attrInsp.featureLayers = [myFeatureLayer]" mapClick="map_mapClickHandler(event)" openHandCursorVisible="false"> <!-- Extent for Woukesha Signs --> <esri:extent> <esri:Extent xmin="2468000" ymin="371000" xmax="2475000" ymax="376000"> <esri:SpatialReference wkid="32054"/> </esri:Extent> </esri:extent> <esri:ArcGISDynamicMapServiceLayer url="https://maps.ags.ruekert-mielke.com/AGS/rest/services/WaukeshaCity/WaukeshaSignsSampleSigns/MapServer"/> <esri:ArcGISDynamicMapServiceLayer url="https://maps.ags.ruekert-mielke.com/AGS/rest/services/WaukeshaCity/WaukeshaSignsSampleApp2/MapServer"/> <esri:FeatureLayer id="myFeatureLayer" mode="selection" outFields="[HouseNumber,StreetName]" selectionColor="0x000000" selectionComplete="myFeatureLayer_selectionCompleteHandler(event)" url="https://maps.ags.ruekert-mielke.com/AGS/rest/services/WaukeshaCity/WaukeshaSignsSampleSigns/MapServer/0"/> <esri:GraphicsLayer id="myGraphicsLayer"> <esri:Graphic> <esri:geometry> <esri:MapPoint x="2471315" y="374682" spatialReference="{new SpatialReference(32054)}"/> </esri:geometry> </esri:Graphic> </esri:GraphicsLayer> <esri:infoWindowContent> <s:BorderContainer> <esri:AttributeInspector id="attrInsp"/> </s:BorderContainer> </esri:infoWindowContent> </esri:Map> <s:Label text="The feature layer has {myFeatureLayer.selectedFeatures.length} selected feature(s)."/> </s:Application>
