Hello,I have two layers : Rivers (as a polyline shapefile) and lakes (as a polygon shapefile). I want to create a new layer of proximity factor to the streams (Rivers and lakes) which varies by intervals from 5 (near the streams) to 1 (the most distant zones).I used Merge and Union tools. Also I transformed these layers to Raster and I used Euclidean Distance in ArcGIS 10.2... but these solutions didn't work.Can you show me which solution is the most appropriate to this study case ? Thank you in advance
Just I inform you that I tried to combine in a unique raster named Constraints:- The water raster obtained from rivers and lakes layers (having the value 1). - Roads raster which has the value 100.- NonForest raster which has the values 1 and 0 (1 for NonForest pixels and 0 for Forest pixels).So I used Raster Calculator: [Constraints]=[water] + [Roads]+[NonForest]The result was incomprehensible raster representing points scattered in space and having the values 101 and 102.I found the same result when I tried to create the following raster (Raster Calculator): [Soil Loss]=[Factors]-[Constraints].
