I updated the code as you suggested and it did fix the issue. Are there reference pages for the scope you had mentioned?
function startEditing() { dojo.connect(app.map, "onLayersAddResult", initEditor); var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("/arcgis/rest/services/app_services/AMLedit/MapServer", { id: "unique_textID1", opacity: 0.8 }); dynamicLayer .setDisableClientCaching(true); app.map.addLayer(dynamicLayer); var operationsPointLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/0", { id: "amlPoints", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"] }); var operationsLineLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/1", { id: "amlLines", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], }); var operationsPolygonLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/2", { id: "amlPolygon", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], }); var operationsProblemsLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/3", { id: "amlProblems", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], }); app.map.addLayers([operationsPointLayer, operationsPolygonLayer, operationsLineLayer, operationsProblemsLayer]); dynamicLayer.refresh; }
//create a dynamic service of the featureservice layers so you can refresh the map var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://myServer/arcgis/rest/services/myEditService/MapServer", { id: "unique_textID1", opacity: 0.8 }); dynamicLayer .setDisableClientCaching(true); map.addLayer(dynamicLayer ); //example of your operational layers (edit layers) var myeditLayer1 = new esri.layers.FeatureLayer(("http://myServer/arcgis/rest/services/myEditService/FeatureServer/0", { id: "editLayer1"}); //add code in your applyEdits success dynamicLayer.refresh()
dojo.require("esri.map"); dojo.require("dijit.form.CheckBox"); dojo.require("dijit.form.HorizontalRule"); dojo.require("dijit.form.HorizontalRuleLabels"); dojo.require("dijit.form.HorizontalSlider"); dojo.require("dijit.form.Slider"); dojo.require("dijit.form.Select");0 dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.TitlePane"); dojo.require("esri.dijit.editing.Editor-all"); dojo.require("esri.dijit.InfoWindow"); dojo.require("esri.dijit.Legend"); dojo.require("esri.dijit.Measurement"); dojo.require("esri.dijit.Print"); dojo.require("esri.dijit.Scalebar"); dojo.require("esri.graphic"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.layers.graphics"); dojo.require("esri.layers.wms"); dojo.require("esri.SnappingManager"); dojo.require("esri.symbol"); dojo.require("esri.tasks.identify"); dojo.require("esri.tasks.PrintTask"); dojo.require("esri.toolbars.draw"); dojo.require("esri.toolbars.navigation"); dojo.require("esri.virtualearth.VETiledLayer"); if (dojo.isIE <= 7) { alert("This application is designed for version 8 or above. Please upgrade you browser."); } var app = {}; var toolbar; app.map = null; app.printer = null; var addLayerListener; var polygonfeatureLayer, linefeatureLayer, pointfeatureLayer; require(["dojo/parser", "dojo/ready", "dijit/form/Button", "dijit/layout/ContentPane", "dijit/layout/BorderContainer", "dijit/layout/TabContainer", "dijit/layout/AccordionContainer"], function (parser, ready) { ready(function () { parser.parse(); }); }); //===================================================================================================================================================== //===================================================================================================================================================== function init() { var initExtentwgs = new esri.geometry.Extent({ "xmin": -9199944.9853, "ymin": 4467222.3562, "xmax": -8651646.412, "ymax": 4959210.1126, "spatialReference": { "wkid": 102100 } }); var initExtentWM = esri.geometry.geographicToWebMercator(initExtentwgs); var levels = [{ "level": 0, "resolution": 156543.03392800014, "scale": 5.91657527591555E8 }, { "level": 1, "resolution": 78271.51696399994, "scale": 2.95828763795777E8 }, { "level": 2, "resolution": 39135.75848200009, "scale": 1.47914381897889E8 }, { "level": 3, "resolution": 19567.87924099992, "scale": 7.3957190948944E7 }, { "level": 4, "resolution": 9783.93962049996, "scale": 3.6978595474472E7 }, { "level": 5, "resolution": 4891.96981024998, "scale": 1.8489297737236E7 }, { "level": 6, "resolution": 2445.98490512499, "scale": 9244648.868618 }, { "level": 7, "resolution": 1222.992452562495, "scale": 4622324.434309 }, { "level": 8, "resolution": 611.4962262813797, "scale": 2311162.217155 }, { "level": 9, "resolution": 305.74811314055756, "scale": 1155581.108577 }, { "level": 10, "resolution": 152.87405657041106, "scale": 577790.554289 }, { "level": 11, "resolution": 76.43702828507324, "scale": 288895.277144 }, { "level": 12, "resolution": 38.21851414253662, "scale": 144447.638572 }, { "level": 13, "resolution": 19.10925707126831, "scale": 72223.819286 }, { "level": 14, "resolution": 9.554628535634155, "scale": 36111.909643 }, { "level": 15, "resolution": 4.77731426794937, "scale": 18055.954822 }, { "level": 16, "resolution": 2.388657133974685, "scale": 9027.977411 }, { "level": 17, "resolution": 1.1943285668550503, "scale": 4513.988705 }, { "level": 18, "resolution": 0.5971642835598172, "scale": 2256.994353 }]; app.map = new esri.Map("mapDiv", { wrapAround180: true, extent: initExtentWM, logo: false, lods: levels, sliderStyle: "large", fadeOnZoom: true }); require(["dojo/ready", "esri/map", "dojo/dom", "dojo/on", "dep/Switcher"], function (ready, map, dom, on, switcher) { ready(function () { on(app.map, "onLoad", new function () { var switcher = new dep.Switcher({ map: app.map, panel_div: "menuDiv" }); }); }); }); esri.config.defaults.geometryService = new esri.tasks.GeometryService("/arcgis/rest/services/Utilities/Geometry/GeometryServer"); } function startEditing() { dojo.connect(app.map, "onLayersAddResult", initEditor); var operationsPointLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/0", { id: "amlPoints", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"] }); var operationsLineLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/1", { id: "amlLines", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], }); var operationsPolygonLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/2", { id: "amlPolygon", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], }); var operationsProblemsLayer = new esri.layers.FeatureLayer("/arcgis/rest/services/app_services/AMLedit/FeatureServer/3", { id: "amlProblems", mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], }); app.map.addLayers([operationsPointLayer, operationsPolygonLayer, operationsLineLayer, operationsProblemsLayer]); } //================================================================= function initEditor(results) { var templateLayers = dojo.map(results, function (result) { return result.layer; }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, rows: "auto", columns: 2 }, "editorDiv"); templatePicker.startup(); var layerInfos = dojo.map(results, function (result) { return { 'featureLayer': result.layer }; }); var settings = { map: app.map, geometryService: new esri.tasks.GeometryService("/arcgis/rest/services/Utilities/Geometry/GeometryServer"), templatePicker: templatePicker, layerInfos: layerInfos, }; var params = { settings: settings }; editorWidget = new esri.dijit.editing.Editor(params); editorWidget.startup(); }
