Dim identifyTask2 As New IdentifyTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/" & "Demographics/ESRI_Census_USA/MapServer") Dim identifyTask2 As New IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/" & "Demographics/ESRI_Population_World/MapServer") Dim identifyTask2 As New IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/" & "Demographics/USA_Unemployment_Rate/MapServer") Dim identifyTask2 As New IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/" & "Reference/ESRI_BoundariesPlaces_World_2D/MapServer") Dim identifyTask2 As New IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/" & "Demographics/USA_Median_Household_Income/MapServer")
'=========================================================================================================================== ' IDENTIFY START '=========================================================================================================================== Private Sub QueryPoint_MouseClick(ByVal sender As Object, ByVal e As ESRI.ArcGIS.Client.Map.MouseEventArgs) Dim clickPoint As ESRI.ArcGIS.Client.Geometry.MapPoint = e.MapPoint Dim identifyParams As ESRI.ArcGIS.Client.Tasks.IdentifyParameters = New IdentifyParameters() With {.Geometry = clickPoint, .MapExtent = MyMap.Extent, .SpatialReference = MyMap.SpatialReference, .Width = CInt(Fix(MyMap.ActualWidth)), .Height = CInt(Fix(MyMap.ActualHeight)), .LayerOption = LayerOption.visible} Dim identifyTask2 As New IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/" & "Demographics/USA_Median_Household_Income/MapServer") AddHandler identifyTask2.ExecuteCompleted, AddressOf IdentifyTask2_ExecuteCompleted AddHandler identifyTask2.Failed, AddressOf IdentifyTask2_Failed identifyTask2.ExecuteAsync(identifyParams) Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyLayer"), GraphicsLayer) graphicsLayer.ClearGraphics() Dim graphic As New ESRI.ArcGIS.Client.Graphic() With {.Geometry = clickPoint, .Symbol = PushPinPictureSymbol} graphicsLayer.Graphics.Add(graphic) End Sub Public Sub ShowFeatures(ByVal results As List(Of IdentifyResult)) _dataItems = New List(Of DataItem)() If results IsNot Nothing AndAlso results.Count > 0 Then IdentifyComboBox.Items.Clear() For Each result As IdentifyResult In results Dim feature As Graphic = result.Feature Dim title As String = result.Value.ToString() & " (" & result.LayerName & ")" _dataItems.Add(New DataItem() With {.Title = title, .Data = feature.Attributes}) IdentifyComboBox.Items.Add(title) Next result ' Workaround for bug with ComboBox IdentifyComboBox.UpdateLayout() IdentifyComboBox.SelectedIndex = 0 End If End Sub Private Sub cb_SelectionChanged(ByVal sender As Object, ByVal e As SelectionChangedEventArgs) Dim index As Integer = IdentifyComboBox.SelectedIndex If index > -1 Then IdentifyDetailsDataGrid.ItemsSource = _dataItems(index).Data End If End Sub Private Sub IdentifyTask_ExecuteCompleted(ByVal sender As Object, ByVal args As IdentifyEventArgs) IdentifyDetailsDataGrid.ItemsSource = Nothing If args.IdentifyResults IsNot Nothing AndAlso args.IdentifyResults.Count > 0 Then 'If DataGridScrollViewer.Visibility = Visibility.Collapsed Then If IdentifyResultsPanel.Visibility = Visibility.Collapsed Then IdentifyResultsPanel.Visibility = Visibility.Visible IdentifyGrid.Height = Double.NaN IdentifyGrid.UpdateLayout() End If ShowFeatures(args.IdentifyResults) Else IdentifyComboBox.Items.Clear() IdentifyComboBox.UpdateLayout() If IdentifyResultsPanel.Visibility = Visibility.Visible Then IdentifyResultsPanel.Visibility = Visibility.Collapsed IdentifyGrid.Height = Double.NaN IdentifyGrid.UpdateLayout() End If End If End Sub Public Class DataItem Private privateTitle As String Public Property Title() As String Get Return privateTitle End Get Set(ByVal value As String) privateTitle = value End Set End Property Private privateData As IDictionary(Of String, Object) Public Property Data() As IDictionary(Of String, Object) Get Return privateData End Get Set(ByVal value As IDictionary(Of String, Object)) privateData = value End Set End Property End Class Private Sub IdentifyTask_Failed(ByVal sender As Object, ByVal e As TaskFailedEventArgs) MessageBox.Show("Identify failed. Error: " & e.Error.Message) End Sub
Private Sub QueryPoint_MouseClick(ByVal sender As Object, ByVal e As ESRI.ArcGIS.Client.Map.MouseEventArgs) Dim clickPoint As ESRI.ArcGIS.Client.Geometry.MapPoint = e.MapPoint Dim identifyParams As ESRI.ArcGIS.Client.Tasks.IdentifyParameters = New IdentifyParameters() With {.Geometry = clickPoint, .MapExtent = MyMap.Extent, .Width = CInt(Fix(MyMap.ActualWidth)), .Height = CInt(Fix(MyMap.ActualHeight)), .LayerOption = LayerOption.visible} Dim identifyTask2 As New IdentifyTask("http://services.arcgisonline.com/ArcGIS/rest/services/" & "Demographics/USA_Median_Household_Income/MapServer") AddHandler identifyTask2.ExecuteCompleted, AddressOf IdentifyTask2_ExecuteCompleted AddHandler identifyTask2.Failed, AddressOf IdentifyTask2_Failed identifyTask2.ExecuteAsync(identifyParams) Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyLayer"), GraphicsLayer) graphicsLayer.ClearGraphics() Dim graphic As New ESRI.ArcGIS.Client.Graphic() With {.Geometry = clickPoint, .Symbol = PushPinPictureSymbol} graphicsLayer.Graphics.Add(graphic) End Sub
