Dear Friends,I need urgent help for the following issue.I developed one module for Drawing the polygon.These polygon points I am saving to the DB.Everything is working fine with the following URL<esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer" Url="http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" />Now same code I am trying to use with Googlemap.But the longitude and latitude of the same place giving different.For eg:When i draw a polygon on ESRI_StreetMap_World_2D/MapServer .The points like 58.25,23.225 58.232,24.89 58.35,23.225When I draw a polygon on Googlemap withthese same location,The points are 2704315.97807635,6496765.39170823 2704330.31001916,6496775.09562783, 2704315.97807635 6496765.39170823Y it is getting the values like this.I am very confused.Can anybdy help me to solve my issue?PLEASEEEE End Sub
Private Sub MyDrawObject_DrawComplete(ByVal sender As Object, ByVal args As ESRI.ArcGIS.Client.DrawEventArgs)
If TypeOf args.Geometry Is Polygon Then
Dim cntpoints As Integer = DirectCast((args.Geometry), Polygon).Rings(0).Count
If (cntpoints <= 2) Then Exit Sub
Dim points As PointCollection = DirectCast((args.Geometry), Polygon).Rings(0)
'Save the points
For Each mapPoint As MapPoint In points
''''''''''''''''''Save data to DB
VID = VID + 1
Dim ProxySavePoly As ComboLoadClient = New ComboLoadClient()
AddHandler ProxySavePoly.SavePolyGonIDCompleted, AddressOf client_SavePolyGonIDCompleted
ProxySavePoly.SavePolyGonIDAsync(" VALUES(" & PID & " ," & VID & "," & (mapPoint.Y) & "," & (mapPoint.X) & ", " & _
" " & fahrid1 & ",'" & Geofencename & "','" & Geofencedesc & "','" & DateAndTime.Now & "')")
End If
